Comparison of a Victor X IM vs. Skunk2 Ultra Street IM on a GTX3582R powered B16A2?
Hi guys
There is someone that he has tried on B16a 81mm 9:1 ultra street vs victor x?? my rev limit is 9600 now with victor x and pro1 cams... finally pro 1 cams is everywhere better than itr... my question:there is a case to lose power after 9000?? |
Re: Comparison of a Victor X IM vs. Skunk2 Ultra Street IM on a GTX3582R powered B16A
If i had to bet i would say its better everywere.
No data tho. |
Is the reason for your questions the fact that the power is dropping after 9000rpm ?
Originally Posted by extremeracer
(Post 51905295)
Post the dyno plot. I dont think is possible with a victor x + pro1 for power to drop after 8000.
I mean both the cams and the intake manifold are best at 7000 untill like 10500. Maybe you are starting to hit .63 housing top max flow? If it does it only at high boost it may be this. And its different from droping only torque to drop so much torque that even power drop as rpm raise. If it does it at medium boost too its probably something else. |
Originally Posted by Balor_Gr
(Post 51905566)
I mean both the cams and the intake manifold are best at 7000 untill like 10500. Maybe you are starting to hit .63 housing top max flow? If it does it only at high boost it may be this. And its different from droping only torque to drop so much torque that even power drop as rpm raise. If it does it at medium boost too its probably something else. now I have victor and I have not problem after 8000...I mean if I switch from victor x to ultra street if I will lose power after 8000 or more.... |
Originally Posted by fotis2000
(Post 51905585)
misunderstanding...
now I have victor and I have not problem after 8000...I mean if I switch from victor x to ultra street if I will lose power after 8000 or more.... Low compression with the 1.6 probably isn't helping the overall build, but I understand it's more intensive to change a set of pistons than an intake. |
Originally Posted by Chance EG
(Post 51906316)
No, not in conjunction with the Pro1 cams and the GT35. Your torque line should be solid until at least 9500.
(Post 51906366)
You mean than I should stay with victor x??
The Ultra Street would probably be a mild improvement over the Victor X, mostly in the midrange. Personally I wouldn't spend the time or money on the manifold swap and retune though, in the overall scope of your build I think it will be relatively inconsequential. |
(Post 51906407)
I'm not sure how you got that conclusion out of what I said.
(Post 51906604)
I want better response after every shift this is my biggest goal with a smaller intake!
You could also have another restriction in the system like an intercooler, intercooler piping size, downpipe size, air filter etc. **Edit I think you were asking if there is any benefit of the Ultra Street over the VictorX. If that's the question then Yes it will probably give you more mid-range but power will peak earlier and drop off sooner vs the Victor X which is designed for 7000 - 10 000 rpm. A big turbo B16A is never going to have strong mid-range so its not worth the cost or effort if you focused on maximum power. |
(Post 51906814)
You could also have another restriction in the system like an intercooler, intercooler piping size, downpipe size, air filter etc. **Edit I think you were asking if there is any benefit of the Ultra Street over the VictorX. If that's the question then Yes it will probably give you more mid-range but power will peak earlier and drop off sooner vs the Victor X which is designed for 7000 - 10 000 rpm. A big turbo B16A is never going to have strong mid-range so its not worth the cost or effort if you focused on maximum power. This is exactly my question about these 2 IM. If I try to go with 0.82 housing and ultra street??? |
(Post 51906939)
I dont see any benefit switching.
The skunk2 will have better area under the curve. IMHO the Victor X has runners too short for most setups.
Squirting a super soaker at a house fire will help too, but it isn't going to put out the fire.
Id go crazy and convert it to gtx3571 gen 2. It will hit 600 hp and will be much more responsive from GTX35 compressor by A LOT.
And you can sell your gtx35 compressor backplate compressor housing as an upgrade kit to someone that actually wants 750-800 hp. Plus since the new compressor wheel will have more RPM on the turbine shaft for the same HP you reduce back pressure since the turbine wheel will swallow more. Youll need more boost tho and might have the same backressure at the end but still MUCH lighter and much more efficient compessor wheel for what you want. |
(Post 51907741)
(Post 51908074)
My turbo is gt3582 not gtx and I don’t want to try different turbo...I know the route if I want to spent so much money...As we discussed already I need little more mid range...I believe skunk2 ultra street will be better everywhere but I want someone which he has done back to back comparison...
What throttle body and exhaust manifold? |
Originally Posted by LightningTeg
(Post 51908085)
The difference will be negligible.
(Post 51908119)
70mm and ramhorn manifold
(Post 51908626)
Smaller TB and shorter exhaust manifold will make more of a difference IMO
In other words, everyone..... Neither IM will help, nor will the turbocharger and exhaust manifold combination you have. If you want a better torque-band on a B16, change the setup. Plain and simple.
Originally Posted by TheShodan
(Post 51910349)
how is that possible such a huge IM make same mid with ultra street with longer runners can you explain with examples??? |
