Comp Turbo ct4 6465 billet or Precision 6266 billet, for 600hp goal
Hi, I'm looking for suggestions for actually doing these two turbines, which would work best and which of the two is better quality. Both turbos with a / r .63 Turbine housing. which of the two produces more horsepower per pound of boost for 600hp goal, street and track car D series fully built!
Re: Comp Turbo ct4 6465 billet or Precision 6266 billet, for 600hp goal
comp turbo is very efficient, nthats wat im using. had the 6765 billet and made 749 on 31lbs with 9:1 comp. going bigger now but sticking with comp
Originally Posted by midnightStretch
(Post 46602162)
Up!!!!!!
1200hp from a 6765?
anyone else have any opinion? which would be my best option for what I want?
Originally Posted by rs250nut
(Post 46606379)
1200hp from a 6765?
(Post 46606379)
1200hp from a 6765?
yup! its only rated for 900+ but check the website if you dont believe that turbo is way underrated. they are running a divided 1.44 A/R on the hot side on a B18C1 on 85mm sleeves the car is a beast. here is a video http://www.youtube.com/watch?v=JSpDocQPqUw
Originally Posted by tagperformance
(Post 46608037)
That's a negative. your looking at around 930whp max and the depends on how big the A/R is on the turbing housing.
Originally Posted by H22AFerio
(Post 46610628)
yup! its only rated for 900+ but check the website if you dont believe that turbo is way underrated. they are running a divided 1.15 A/R or 1.25 A/R on the hot side on a B18C1 on 85mm sleeves the car is a beast. here is a video
OP... A billet 6262 will net you 600 whp with no issues, no need for the larger turbine wheel from the 6266. |
Originally Posted by Silva Bullit DC4
(Post 46610670)
You are speaking of Speed Factory's Hatch, driven by Kevin Kempf that races in the Outlaw Street class, and they are NOT using a 6765. That turbo is not even capable of making that type of power. That particular car is using a Precision billet GT-4272R, or they might have switched to the 7280. They are capable of making 1200+ whp, but the billet 6765 is not.
6262 has routinely given out 700+ easily though.
Originally Posted by SPOOLINmatt
(Post 46610832)
well....possible was thrown out the door when we were making around 750 lol.
basic block with a decent portflow head, ramhorn, magnus intake manifold. 11:1 83mm I promise this power was not a battle to make. |
(Post 46610941)
(Post 46610753)
yes they are running a GT-4272R I just called and spoke with matt . Its james car that was running the 6765H on his D16 before they pulled the motor I apologize for the confusion. ;)
I know it's possible to reach 600 horsepower with a precision 6262, but you have to fit more than 32-34 lb of boost. I am looking for a more efficient turbo to me, a little larger than the 6262 and was the 600 horsepower less than 30 pounds of boost! which of these two brands is more efficient turbos and what you think I work better
It's a D series engine!
is it possible?
on a d series? im speaking of B, sorry
and i believe we were running around 30-34 psi. on a B, we did exactly what i said. I bet600 is doable on the d series. |
(Post 46611110)
I hope those guys come out to the east coast again this year. I saw the car in the pits at World Cup Finals at MIR this past November, and man, pics don't do this car justice at ALL. Beautiful and fast car indeed. :thumbup:
Originally Posted by TheShodan
(Post 46611038)
Sure.. ok. Perhaps it was a "dyno" measurement thing, as it was different in our experiences with it. But if you say so, ok.
I'm making 560whp on a .68ar 6262bb @ 25 psi. With a b18c 9.1 compression. Could easily break 600 but max my 1200cc injectors on e85.
With the right parts 6262's will do 700 with no problems. A local b series car i've done fab work on and sold a 6265 to does 770ish @ 25-26psi. Reputable dyno that pretty much any fast car in AZ dyno's on too before that arguement comes up.
but B16 with a 85mm 9.1:1 is good with 6765? I have a 6262 but afraid go to6765 and create more lag
i have PRO1 cams and TB 70mm |
Originally Posted by Evo1
(Post 46619598)
I digress, as this isn't even about me or proving me right or wrong. I don't want to distract from the original point of this thread |
