cometic turbo head gasket, cam gear settings ? anyone know
Hello I have a h22a4 with a .89mm cometic head gasket for turbo applications and I was wondering what settings the aem cam gears should be set at? stock? advanced?
if the settings are at stock rite now, would that cause the car not to start? thanks |
Re: cometic turbo head gasket, cam gear settings ? anyone know (turbobboy)
Stock. You dont need to adjust timing unless your headgasket is 2mm or more.
Re: cometic turbo head gasket, cam gear settings ? anyone know (intekragsr)
does the 2mm measurement come from the spaces on the timing belt?
