college budget - what do i need now with custom turbo kit?
i just bought a turbo kit with turbo, manifold, down pipe, wastegate, and piping. what do i need to get this thing running on stock internals at around 8lbs. and oh yeh im on a college budget! (sux). ive heard so many things that i dont know what is true. so if someone could post a check list for me and tell me what is absolutely neccissary to run 8lbs safe because i need this car for college and cant afford a rebuild. i need to know what i need everything from guages to fuel ****. i hope some one can help.
Re: college budget - what do i need now with custom turbo kit? (97GSRT)
Ok, I'll be first to screw with the newbie.....
Some good info here!
[Modified by 93LSivic, 5:21 PM 3/24/2002]
just get: boost gauge, boost controller, hondata + injectors + fpr + fuel pump (ecu & obd2-obd1 harness if you have obd2 ecu) and oil pressure gauge / egt gauge / turbo timer if you have the cash
Re: college budget - what do i need now with custom turbo kit? (cyan1de)
what do you mean with the (ecu & obd2-obd1 harness if you have obd2 ecu) i have a 97 gsr. are you saying that i need a chip, i thought the hondata took care of all that stuff
yeah hondata can only modify obd1 ecu's not obd2, which you have. i didn't see you have an intercooler in your setup you bought so you'll probably want one. you can get away without using a boost controller by buying a different wastegate spring for your wastegate that's around 8psi.
ok so i need a hondata - does anyone know how long it would be before i had it if i did the group buy?
if anyone has any of these things i need for cheep i have the cash! i need an ic with the piping and all of the listed stuff above so let me know, used is ok as long as it works
New User
if you dont decide to go with Hondata, you can always use the basic turbo kit fuel management setup. Vortech FMU and inline fuel pump. dont forget the Missing Link check valve for your map sensor. i got the fmu, fuel pump, and check valve for sale. just hit me up. peace.
Re: college budget - what do i need now with custom turbo kit? (dlplayboy)
if i dont do a stand alone and go with something like the vortech fmu do i need to an ecu still?
ok so do i need injectors with the vortech fmu or are they not needed either?
also if anyone has an ic for cheep i need one, piping would be good too
let me know!
Dionysus3@comcast.net
let me know!
You will need this book before you do anything. http://www.amazon.com/exec/obidos/AS...698473-2135361
i like the idea of the fmu and and other stuff dlplayboy but i need to know if an apexi controller and injectors are needed
New User
Check my website below. Under Randy's parts you will see all you need to run around 7psi.
I have a vortech FMU with 12:1 and 10:1 discs to sell. E-mail me.
I can help you with oil lines and install headaches, just drop me an e-mail.
Thanks,
Randy
Thanks,
Randy
Re: college budget - what do i need now with custom turbo kit? (zojirushi)
http://www.Homemadeturbo.com probably the best place to start, it helped me alot, i built a fully custom kit with the help of my friends that looks,performs,and runs better then any other prefab **** kit out there. i am making 189.7fwhp on 9lb of boost untuned!! on a D16y8
Smarter than you
Re: college budget - what do i need now with custom turbo kit? (Civ-JDM)
alright dude..By the book maximum boost, then when u r done reading it come back here.. Basically your gonna need a fuel system and in intercooler, a clutch and some gauges..
For cheap you could probably get an FMU and inline fuel pump..not the best set up but it works.. Not saying it works good, but it works.. Or you can go with something like hondata that they have described above..
youll need some gauges.. IMO u dont need anything more then boost and a/f.. OR EGT.. If u r on a budget id say just get the autometer they are easily affordable..
youll probably want a boost controller.. best way to do that for cheap is a turbo XS mbc.. I have one i like it..
intercooler/piping and clutch, those will probably cost u some loot..
im assuming u already have an exhaust, you can get an intake fabricated, youll need oil feed/oil return lines..
honestly, read the book and do some searching on the site.. dont rush into it..
Re: college budget - what do i need now with custom turbo kit? (DIRep972)
here is another good site you need to visithttp://www.howstuffworks.com/turbo.htm
Re: college budget - what do i need now with custom turbo kit? (Ltech)
Man make the intercooler pipe your self!!! why pay 300 for pipe that cost $60 i orderd all the pipe needed to make an intercooler chopped it up and fit piece's together then went back and had a friend weld them. all for a lousy $46 and thats includuing the custom DP i made. 3" DP by the way
