Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   CODE 16 trouble starting (https://honda-tech.com/forums/forced-induction-16/code-16-trouble-starting-1317917/)
Turbo_Mike Jul 24, 2005 09:50 AM
Just yesterday i parked my car for an hour in the sun, came out to start it and it hiccuped then wouldnt start. It started throwing a code 16. After a while i reset the ecu and it started up fine. Ended up doing this 3 more times that night. The last time i got gas and shut it off. It started hard but i got it going. PUlled out on the road and it was only revving to 3 grand so i pulled over to reset the ecu again.
I converted from pre to obd1 and i'm using uberdata. All injector clips are on good, and this problem just started yesterday. wHERE can i look to fix this problem?
Turbo_Mike Jul 24, 2005 06:54 PM
Re: CODE 16 trouble starting (MIKE JONES)
https://honda-tech.com/forums/images...es/emdgust.gif
boosted k20 Jul 25, 2005 05:50 AM
do u have a resistor box? check that. also pull the fuel rail out with the injectors still attached. have a friend try to crank the car to see if one of the injectors went bad. but check the resistor box if u have one 1st
Turbo_Mike Jul 25, 2005 06:25 AM
Re: CODE 16 trouble starting (boosted k20)
yea i converted to mpfi a few years ago, and i have never had a problem with the resistor box.
Turbo_Mike Jul 25, 2005 04:59 PM
