Civic92turbo build LSVSUPER
hey guys wanted to share my build hopefully going to hit 250+ with out NOS
And Why a SuperCharge? i had it laying around from my brother destorying his old b16 also inputs are welcome
81.mm Ls B18b Block
Crower Rods
Blue print/Balance crank
Arp Main Studs
Crower Rod Bolts
Cp 9.1 Pistons
GSR Oil Pump
B20 Crank Pulley
B16A2 Head
Stage 2 Pnp Street Version
Super Tech Valve Springs
Super Tech Flat valves To raise comp alittle
GE LsVtec Kit
ARP Head Studs
sKUNK 2 CAMGEARS
b16A2 Stock Cams
Jackson Super Charger Stock 7 Lbs/ but should bump up tp 10 Lb with the B20 Crnak Pulley
Nitrous Express 75 shot Wet kit
Will post numbers and picks in a week or 2... just finish the build
81.mm Ls B18b Block
Crower Rods
Arp Main Studs
Crower Rod Bolts
Cp 9.1 Pistons
GSR Oil Pump
B20 Crank Pulley
B16A2 Head
GE LsVtec Kit
ARP Head Studs
sKUNK 2 CAMGEARS
b16A2 Stock Cams
