chevron vs 76 ( 76 gains the most hp, dyno proven) old, but maybe new to some pple
if you got a turbo car use 76
click on the link below for more information
http://www.evolutionm.net/foru...26776
Chevron (91) 284WHP and 290TQ - chart 1
76 gas (91) 298WHP and 298TQ - chart 2
CHART 1 Chevron (91) 284WHP and 290TQ
CHART 2 76 gas (91) 298WHP and 298TQ - chart 2
crazy hp gain huh? i dont believe it completely so when i get my dyno machine in a half a year, im goin to test it out myself
Re: chevron vs 76 ( 76 gains the most hp, dyno proven) old, but maybe new to some pple (playboyace35
May not be a good thing. The 76 may be of lower octane.
you make the most whp with the lowest octane you can go before detenating.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 »</TD></TR><TR><TD CLASS="quote">you make the most whp with the lowest octane you can go before detonating.</TD></TR></TABLE>
Exactly. Higher octane means slower burning.
Phil
Phil
hence... when you dyno.. and you add race gas afterwards = LESS POWER
because the higher octane is harder to burn. needs more timing to ignite.
those results can easily be skewed by .. say .. colder climates. new set of spark plugs. doing multiple runs to try to beat the old WHP.
the thing with turbo cars is ... power can increase or decrease dramatically depending on conditions. whereas all mtor cars i find to be more stable and results easily repeatable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef »</TD></TR><TR><TD CLASS="quote">
Phil</TD></TR></TABLE>
no that is incorrect...
the chemical make up of the fuel has to do with the burn rate.
octane is simply the resistance to detonation.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase »</TD></TR><TR><TD CLASS="quote">
octane is simply the resistance to detonation. </TD></TR></TABLE>
its the additives they add that makes it slower burn
So, you're telling me lower octane like pump 87 thru 93(the entire fuel makeup not just the rating) does not have a faster burn rate than say......C16?
Phil
Phil
c16 does burn much slower.
but not because of octane.
"VP Import" has 3+ more points of octane over C16 and burns MUCH faster. octane is not equal to burn rate.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enthalpy »</TD></TR><TR><TD CLASS="quote">c16 does burn much slower.
"VP Import" has 3+ more points of octane over C16 and burns MUCH faster. octane is not equal to burn rate.</TD></TR></TABLE>
OK, I need an explination then so, I can be correclty guided. I see why it can be different now. That VP import is formulated to burn quicker because of the High RPM's associated w/ our engines therefore less time to actually complete the burn (due to high rpm). Does specific gravity have an affect on burn rate? Please explain.
Phil
Phil
http://auto.howstuffworks.com/question90.htm
a nice little article on octane.
I have a really good article on gasoline, octane, etc in a sport compact or something magazine. Tells a LOT about specifics of how they increase octane, whats good/bad octane, etc. Maybe I'll scan it sometime before all the pages fall out.
Basicly, a simple thing as when (time of day, time after last tanker refill) you filled up can make a difference. Best time IIRC is in the morning. One reason you can sometimes see more power with lower octane is if the chemical that boosts the octane number is the worse of the boosting chemical (3 major/common types, I think toluine, benzine and something else). Sounds weird, I know.
Simply put, I wouldn't sell the farm over a 2.7% increase in torque.
SuicideSlide
27
11-30-2004 10:41 AM
Shugg
10
11-19-2001 08:58 AM
