cherry bomb glass pack
hi i was wondering if any of you guys and girls have ran these on a forced induction set up?
89 crx,b18b,t3/t4
89 crx,b18b,t3/t4
Re: cherry bomb glass pack
Put a glasspack too close to a heat source (turbo or catalytic converter), and you'll only have a "muffler" temporarily as the heat blows out the glass, leaving a nice echo chamber / megaphone in its place.
I found this one out the hard way. 1979 Triumph Spitfire, 4-1 header, cat, glasspack, split, glasspacks, tips. My middle glasspack turned hollow in about 3 months, shooting sparks of burning glass out the tips on WOT pulls while it did so.
Just something to consider when choosing a fiberglass packed muffler.
Yes.
A gutted cat is already an echo/expansion chamber and nothing more. It should (in theory) cool the exhaust slightly as it passes through. A working cat will heat the exhaust passing through it from the final burning of unburned fuel.
I believe that somewhere in the range of 300*F increase in temp is not uncommon, but please don't take that number as gospel, just what I think I remember from reading.
No clue what actual temp is damaging to glasspacks, and every brand will be different (I would assume anyway). My 2nd stage of glasspacks (after the rear axle) seem intact after 15 years of use, but the one immediately following the cat blew out quickly.
