checking timing
my timing is jumpy and i can't get a definitive number because the white mark on the crank pulley doesn't line up with the pointer on the timing belt cover. it would line up to the pointer for a quick moment and fluctuate back and forth.
i'm running JG turbo camshafts on my LS engine, would this be a factor with this timing issue? i'm using the Craftsman advanced timing gun with the dial. |
Re: checking timing (Hatch4urSnatch)
when you shoot the timing light at the crank pully you are supposed to look for the red mark that has the 2 marks above and below it.. i have never seen the white mark appear with a timing light only the red one..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch4urSnatch »</TD></TR><TR><TD CLASS="quote">my timing is jumpy and i can't get a definitive number because the white mark on the crank pulley doesn't line up with the pointer on the timing belt cover. it would line up to the pointer for a quick moment and fluctuate back and forth.
i'm running JG turbo camshafts on my LS engine, would this be a factor with this timing issue? i'm using the Craftsman advanced timing gun with the dial. </TD></TR></TABLE> make sure you jump your ECU. it will smooth it out |
Re: checking timing (Mase)
also the reason u see the white mark is because your shooting 16 degrees of advance
nextelbuddy isnt using an advance gun, thus thats why u are at the red. |
my bad lol i didnt see the last part of his post... i learn something new every day.
i didnt jump my ecu when i set my timing on the dizzy when i used a timinglight.. would reseting the ECU take care of me not jumping it at the time? |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase »</TD></TR><TR><TD CLASS="quote">
make sure you jump your ECU. it will smooth it out</TD></TR></TABLE> yes, the ECU was jumped prior to checking the timing. thanks for the suggestion though. |
| All times are GMT -8. The time now is 07:18 AM. |
