Checking Motorola 2.5 Bar readings?
I've wired the sensor to my LM1. I was wondering what reading are you all getting at certian points. At idle in neutral, I am getting a reading of .97 volts. If I start boosting, I get reading of over 5 volts (I'm only boosting at 4 psi or so, for right now). I read the spec sheet and it says that the operating range for this sensor is 2.9 psi and upwards.
Any ideas?
Any ideas?
Re: Checking Motorola 2.5 Bar readings? (scartail)
heres the data sheet
http://rocky.digikey.com/WebLi...S.pdf
Re: Checking Motorola 2.5 Bar readings? (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scartail »</TD></TR><TR><TD CLASS="quote">I've wired the sensor to my LM1. I was wondering what reading are you all getting at certian points. At idle in neutral, I am getting a reading of .97 volts. If I start boosting, I get reading of over 5 volts (I'm only boosting at 4 psi or so, for right now). I read the spec sheet and it says that the operating range for this sensor is 2.9 psi and upwards.
Any ideas?</TD></TR></TABLE>
Anyone have any further info on the 2.5bar? I'm looking to simply tap in and use the data for logging into my LM-1. I know the sensor is linear... but i'm looking for aproximate Voltage to Vac/PSI rates so I can create a readable gauge in the datalogger.
Re: Checking Motorola 2.5 Bar readings? (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">Anyone have any further info on the 2.5bar? I'm looking to simply tap in and use the data for logging into my LM-1. I know the sensor is linear... but i'm looking for aproximate Voltage to Vac/PSI rates so I can create a readable gauge in the datalogger.</TD></TR></TABLE>
I wuv u! Heh, now to go convertin kPa into something I can use
Heh, and I wish I could datalog the 2.5bar correctly with Turboedit too... ah well... LM-1 will work
poormans_typer69
10-30-2007 05:10 PM
