Chance EG Build Thread - Restomod With Arashi Turbo, Tucked AC, Etc
1993 Civic Si
Work on this car has been in motion at various speeds for the last 7 years, as I juggled other things in my life like moving, establishing a career, relationships, etc. I first started putting plans together for this build over 10 years ago, when I previously had a bolt-on GSR swapped white CX hatch. As with any major project, there are times I'm excited for what I have, but other long stretches where I mostly just feel stressed and anxious. I'm definitely ready to finish this Civic. The goal for this car is to build a reliable and effective weekend warrior & track combo car, with emphasis on keeping the car COMPLETE and approaching all jobs as meticulously as possible (for an amateur enthusiast working in a home garage). I also have a mental goal for how I want the car to look aesthetically, by no means will it be an immaculate show car (nor do I want it to be), but good enough for a local meet. As I've gotten older I've become more and more sour at how many people trash these cars with "budget" build bullcrap, doing things like gutting the entire car or "deleting" any system that's not related to moving the car forward. These chassis offer amazing potential, and it really pisses me off how many people go completely half assed with them and don't bring them justice, even worse often ruining the car for any future buyers. In my case it's VERY safe to say that I've gone to the other extreme and spent more money than was necessary, on parts that I'm sure I didn't need, but this was for peace of mind as well as to complete the car in the image that I had. I also realize that the market for these cars is constantly shrinking, so if there was an aftermarket gizmo that looked appealing to me, I bought it before they're gone. This build already consists of many parts that are discontinued, from companies no longer in existence, etc. Unfortunately I don't have many pictures of the car when I first purchased it. It had been in a fender bender and the passenger corner light was held in with duct tape, the sunroof had been leaking and had a fried motor so they RTV'd it shut, the paint was awful and peeling away, etc. The previous owner also managed to completely mangle multiple factory wire harnesses through some of the worst mod installation attempts I've ever seen, and also broke mounting tabs inside the dash. I certainly bought into an uphill battle, but have few regrets considering how hard it is to find EG Si's these days. Almost everything on this car has been done by myself, or with the help of my dad. My dad doesn't have a lot of experience with cars, but has spent a lot of time doing home repairs, renovations, and other general DIY projects so he's had some very valuable insight at various points with the best way to mount or route certain things, etc. The only things on the car that haven't been done in my own garage is the body paint job, and the internal engine assembly (built by "Honda Mike" in San Antonio). Parts List (not exhaustive): Engine: B16A CSS Sleeved Swap W/ Tucked Power Steering & AC Wiseco 10.5:1 Pistons Callies H Beam Rods Skunk2 Tuner1 Cams GE Adjustable Cam Gears Full Supertech valvetrain W/ 85lb springs ADD W1 Block Girdle W/ ARP Main Studs ACL Orbit Oil pump ATI Super Street Pulley Engine Accessories: Skunk2 Ultra Street Manifold & 70mm Alpha Throttle Body Go-Autoworks 3 Row Half Sized Radiator W/ Spal Fan & Shroud Circuit Hero Cooling Plate Weapon-R Engine Torque Damper Works Engineering Lightweight Alternator & PS Pulleys Chase Bays Power Steering Kit Chase Bays Coolant Overflow 1320 68a Billet Engine Mounts Blox 3” Velocity Stack W/ Filter, Custom Intake & Airbox Turbo: Go-Autoworks RR Manifold W/ 2.5 -> 3” flared Down Pipe & Open Dump Tube Arashi GTX2860R W/ T31 2.5” Vband Out Housing Treadstone TR6 Intercooler Tial MV-S 38mm WG HKS SSQV BoV PTP T3 Lava Blanket W/ Springs, Wastegate Blanket & Wrapped Pipes Ignition & Injection MPC Gold -8an Fuel Rail W/ AEM FPR, Devsport Tucked Fuel Lines & Inline Filter Injector Nation 1000cc Injectors Grams 255lph Fuel Pump Dragonfire OBD1 Distributor Devil’s Own Meth Injection Kit W/ DO3, Failsafe, Float Indicator, Washer Reservoir Tank Transmission/Drivetrain: 98+ Spec ITR Transmission W/ Mfactory 4.71FD, Synchrotech Syncros & Sleeves Clutch Masters Pressure Plate & Full Face Sprung Clutch, ACT Streetlite Flywheel Ktuned Circuit X Shifter Insane Shafts 500WHP Axles & Half Shaft Hasport Shift Linkage W/ Dyno Designs Tyrannosaur Linkage Joint & Bushings Ktuned CMC Reservoir Ktuned Slave Cylinder Performance Electronics: P28 ECU W/ Hondata S300 (New Capacitors, Boost Control, Bluetooth Module) Rywire OBD1 Tucked Engine Harness & Charge Harness PowerTune Digital Dash W/ GPS, Cluster & Instrument Lights Triple Gauge Pillar Pod W/ AEM X-Series AFR, Boost, and Oil Pressure Gauges Billet Battery Relocation Tray (Hidden under rear hatch interior) Wheels & Brakes: Gram Lights 57DR 15x8 +35 Wheels 245/40/15 Front & 225/45/15 Rear Tires ITR 7/8” Master Cylinder W/ Honed Master Cylinder Brace Honed Brake Booster Delete W/ Relocated Clevis Honed 986 Front Brake Kit W/ Brembo Calipers & 11.6” Slotted Rotors & Stainless Lines Wilwood 11” Rear Brake Kit & Stainless Lines MPC Brake Tuck Kit Honed Adjustable Pedal Set Accessories: Various bling parts from PW:JDM before they went out of business, Downstar, etc. Suspension: Progress CS2 Coilovers (450/350) (will be upgraded later) TruHart Traction Bar MPC Extended Top Hats Skunk2 Pro Front & Rear Camber Kit Benen Front Lower Tie Bar ASR Subframe Brace ASR 24mm Rear Sway Bar Beaks Rear Lower Tie Bar Function 7 Rear LCA Hard Race Front LCA PW:JDM 3 Point Strut Bar Beaks X Brace TruHart Roll Center Adjusters/Ball Joints Interior: NRG 2.5 Quick Release + Hub Personal Grinta 350mm Steering Wheel + Dress Up Bolts Kdezine Rear Seat Delete Diode Dynamics Footwell Lighting OEM JDM Center Console Blox Gold 455g Shift Knob OEM ITR Shift Boot Integra Map Light Exterior & Aero: Seibon Carbon Fiber Hood W/ Aerocatch Latches & TrackSpecMotorsport Civic Louver Vents Mayhem Metalwerkz Front Crash Bar W/ Mounting Tabs Sickspeed Rear Bumper Diffuser Custom Passenger Air Intake/Headlight Combo Weathertech Window Deflectors Mugen Style Front Lip OEM JDM Thin Style Side Moldings Carbon Fiber Duckbill W/ Brake Light Black Housing Headlights W/ Smoked Corners & City Lights Smoked/Red Tail Lights Smoked Flat Side Markers OEM Front & Rear Splash Guards VMS Carbon Fiber Antenna Delete Smoke Fog Lights W/ Carbon Fiber Lense Cover Custom AC Tuck (95 EG EVAP, 98 EK Dryer, Custom Lines & Condenser) |
Re: Chance EG Build Thread - Restomod With Arashi Turbo, Tucked AC, Etc
https://cimg2.ibsrv.net/gimg/honda-t...3d78cb83bb.jpg
https://cimg4.ibsrv.net/gimg/honda-t...88a039dae7.jpg https://cimg2.ibsrv.net/gimg/honda-t...e8015145eb.jpg https://cimg3.ibsrv.net/gimg/honda-t...a4ca25f1c8.jpg https://cimg4.ibsrv.net/gimg/honda-t...85818e9c9c.jpg https://cimg5.ibsrv.net/gimg/honda-t...fe620bf0c9.jpg https://cimg6.ibsrv.net/gimg/honda-t...455898bb09.jpg https://cimg7.ibsrv.net/gimg/honda-t...d93760be36.jpg |
https://cimg1.ibsrv.net/gimg/honda-t...edc9c16891.jpg
https://cimg3.ibsrv.net/gimg/honda-t...c63ea0eb69.jpg https://cimg4.ibsrv.net/gimg/honda-t...46a45768b9.jpg https://cimg7.ibsrv.net/gimg/honda-t...5c7dce6dd7.jpg https://cimg1.ibsrv.net/gimg/honda-t...f8bbfd8f26.jpg https://cimg8.ibsrv.net/gimg/honda-t...49b454a0dd.jpg https://cimg9.ibsrv.net/gimg/honda-t...78a7dd5441.jpg |
Today:
https://cimg5.ibsrv.net/gimg/honda-t...22daf0f5bb.jpg https://cimg8.ibsrv.net/gimg/honda-t...c53fb51169.jpg https://cimg9.ibsrv.net/gimg/honda-t...20e55ed1dc.jpg https://cimg1.ibsrv.net/gimg/honda-t...0073418061.jpg https://cimg2.ibsrv.net/gimg/honda-t...fba2818f42.jpg Manifolds and turbo just loosely mocked up, nothing is torqued down. I highly doubt that Downstar hardware on the exhaust manifold will work without backing out, I may or may not actually try to use it. Otherwise I'll use studs + wedge washers. |
Just working on things at random today, more test fitting. Have a few bolts I'll need to find replacements for.
Working on getting the turbo clocked the way it needs to be, and the oil/water feed/drain sorted out - Looks like it should be a pretty straightforward affair. May get the intake side torqued down today. There's one exhaust stud that's SUPER stuck in the head that I can't get out which is preventing me from torquing down the hot side. On that note though, I will also be replacing that Downstar exhaust hardware with some studs and wedge washers, I'd just be a lot more confident in that. I think the intake manifold will be ok on the bolts since that side of the engine sees a lot less heat and also holds less weight. |
Turbo clocked in a good position. I think I'm going to get a different drain flange for the turbo, one with a straight 10AN coming off so I can use a 45 deg fitting after it. Also got the distributor mocked up and half shaft on. Turbo studs are torqued with blue loctite into the exhaust manifold (literally the only thing that's actually torqued down right now).
Oil feed may be an issue, will likely need to either angle the turbo slightly which I'd like to avoid, or try to find a banjo fitting that could work with the feed line. If anyone knows of something like that let me know. So much easier figuring all this stuff out on an engine stand versus when I had to work on components like this on my old S2K in the engine bay. That was miserable, especially at the time when I was a novice in over my head. https://cimg0.ibsrv.net/gimg/honda-t...39662fc64c.jpg https://cimg4.ibsrv.net/gimg/honda-t...972ca5ac8c.jpg Dragonfire dizzy looks really good, hopefully it performs well and doesn't have any issues with signal. https://cimg1.ibsrv.net/gimg/honda-t...a7cc6be294.jpg Edit: I'm finding some banjo bolt oil feed kits for GT series turbos, that have an integrated 1mm restrictor. Just need to find one that's the right length. I'm going to go ahead and spend the $70 or whatever it ends up costing to change the feed line to that style - I think I could make what I have now work, but it would make serviceability bad because with this current feed, I'd only be able to get it on/off with the turbo off the manifold. Banjo style will just be better. |
It's good to see your car. Everything looks great! I wish I'd done a better job of documenting my work on mine.
Dragon fire distributor DID NOT WORK on a friends setup back in September i think. Caused a bunch of issues that went away with a stock distributor
Originally Posted by Pepe14
(Post 52686045)
New OEM dizzys are $700+, if I do have problems with the Dragonfire I'll either shell out the cash for that or do a COP conversion. The Dragonfire dizzy, ACL oil pump, and Arashi turbo are all parts I'm evaluating on this engine and will be sharing the results here - Of the 3 I think the dizzy is most likely as you said to cause issues. |
In for updates :thumbup: definitely looks like a fun build
What you did with the rear interior came out amazing, how did you end up deciding to go that route? |
Originally Posted by ohisofly
(Post 52686111)
What you did with the rear interior came out amazing, how did you end up deciding to go that route? I don't remember where I originally found this shop, but they build these rear seat delete kits for Civics, Integras, and Foxbody Mustangs: https://kdezines.com/rear-seat-delete I've always liked how hatches look with the rear seats out of the car, but didn't want to just leave it bare. This also offers opportunity for sound deadening. |
Originally Posted by Chance EG
(Post 52686052)
They have a good reputation among domestic cars, but speaking loosely I don't think a lot of those GM/Ford engines are as sensitive as far as CKF sensors and such, especially considering the RPM our engines reach compared to big V8s.
New OEM dizzys are $700+, if I do have problems with the Dragonfire I'll either shell out the cash for that or do a COP conversion. The Dragonfire dizzy, ACL oil pump, and Arashi turbo are all parts I'm evaluating on this engine and will be sharing the results here - Of the 3 I think the dizzy is most likely as you said to cause issues. Fun fact ive never bought a new oem pump, just open the pumps i get with my spare blocks and measure the tolerances and use them. I have opened some that were trashed. I just pulled a pump from the yard because it looked really good and paid 20 bucks for it. No comment on the turbo except if it explodes itll take out a bunch of your parts. |
(Post 52686148)
I dont like the acl pumps either. My drag buddies use them. They just look cheap. Oil seals leak on them. They dont log oil pressure but the bearings never look good. Theres a seller on amazon that sells oem pumps for 160.
Fun fact ive never bought a new oem pump, just open the pumps i get with my spare blocks and measure the tolerances and use them. I have opened some that were trashed. I just pulled a pump from the yard because it looked really good and paid 20 bucks for it. No comment on the turbo except if it explodes itll take out a bunch of your parts. I have a gauge to monitor oil pressure, if anything I'm anticipating to have too high pressure with this pump. Time will answer all questions, these all (should) be good quality parts but don't have as much experience behind them to back them up. As long as (knock on wood) the engine doesn't grenade itself within the first couple months of the car running I can deal with any issues. If it pops during tuning or the first few pulls then yeah I'll be kind of bummed out lol. |
Spent several hours since last evening with several browser tabs open simultaneously while I researched and looked for different odds and ends.
Will be attempting to use a 2000 Civic Si B16 compressor for my AC setup (current one is off my original D16 and not compatible with the fittings I have). Got a pressure switch adapter from Coldhose that should let me splice the OEM high pressure sensor directly into my #6 line. Ordered a 32" -3AN banjo bolt oil feed with an integrated .035" restrictor. Hopefully it's long enough. The banjo fitting should keep me from having to clock the turbo away from true vertical. Also got a different drain flange to try and get a better angle there. Also ordered a 6AN Radium Orb low profile fitting for the water feed to the turbo, and Downstar titanium studs and Nordlock wedge washers to replace the bolts I currently have for the manifold. Getting a spacer for my Vibrant oil cooler because otherwise the block and water pipe are right in the way of where the lines need to come out. I'm spending the extra time now to get everything as perfect as possible. Removing variables, the less things to worry about the better. Having the engine on the stand makes it really easy to see how good or bad fitment is, making the most of the opportunity. |
Labour of love. Makes my project on my '93 look like child's play. Very well done indeed.
Small Update: Found a solution for my AC pressure switch - I have a #6 tee I can use with the high pressure hose, I'll just need to get it spliced in. OEM pressure switch threads right in, two wires to extend and that'll take care of it. Kind of want to buy AC tools myself, but still busy spending money on the few remaining parts I need.
Last variable to get a fully functional tucked AC will be an AC compressor that's compatible with my fittings. I have a compressor from a 2000 Civic Si that should be in soon, I think a B16 compressor that came with R134a from the factory should work. I had the same issue with my 93 Si Evap core with one fitting not working, the Evap slot was either too big/small for what I had available. Switching to a 95 EG Evap core that came with R134a from the factory solved that, so I'm hoping this compressor is the same fix. So theoretically, even an AC compressor from a 94+ Civic SOHC may also work. Or even like a 97 B16 Del Sol. https://cimg3.ibsrv.net/gimg/honda-t...d6029844ee.jpg I'm going to do a separate post writing up the process once I have the AC system proven to work. At this point I've seen several people with a system like this mocked up, but most of them do it in a very hack fashion and I have yet to see a single video of the setup actually running, even from DC5Creations who makes the "kit" (he's had to make several revisions to it on the fly and it's become apparent that he has a poor understanding of his own product). Anyway, figuring it out. |
Chance the motor looks great! What fasteners are you using that are orange? Just for looks or do they serve another purpose?
Originally Posted by Stopsign32v
(Post 52687429)
I got all the hardware from Downstar, when they send you their kits they come with a printout listing the contents of each bag (IE Bag #1 Oil pump, Bag #2 Oil Pan, Bag #3 Water Pump, etc). It just makes the whole process a bit easier, and definitely much more rewarding reassembling everything. The cost, unless it's changed since I ordered, also isn't all that bad IMO - At least not compared to what I'd be spending anyway at Home Depot for new zinc bolts. To me it's a very worthwhile purchase if you're reassembling an engine. |
My AC system has been completely solved and figured out now (pending results of course).
The fittings I have fit the 2000 Si compressor perfectly, and the compressor bolts up of course no problem to the B16A and lines up perfectly with the pulley. I'll have the fittings fully seated later, but you can see here everything will fit great: https://cimg8.ibsrv.net/gimg/honda-t...23fdc54876.jpg So for me the winning combination seems to be: 94-95 Civic Evaporator 1997 Civic Dryer 2000 Civic Si Compressor ClimaParts 10x18" Parallel Condenser W/ #6 and #8 fittings ColdHose #6 Inline Hose Adapter W/ 3/8"-24 Switch Port SPAL 5.2" Puller Fan And then I'm using the AC lines and fittings provided by JackSpania. Note as I've mentioned that neither that kit, nor DC5's are perfect and both will require different degrees of modification and parts swapping depending on what car you're doing this on - In my case with a 93 Si that came with R12, a lot of changes as listed above are needed. I would anticipate that any 94+ Evap core would work, obviously use a 94-95 if you're on an EG or a 96-00 if you're on an EK. Same with the Dryer, I'd expect anything 94-00 Civic to work, and even for the AC compressor likely the same deal 94+, and I'd actually wager even a D series compressor would work. I can only confirm 100% the parts I listed above though. Again, I'm going to post a separate and full write up on this once I have the car running and the AC charged and proven to work. Neat stuff. |
Did you lube those orings??
(Post 52687768)
(Post 52687772)
I also read you can't lube them with oil.
(Post 52687768)
(Post 52687707)
(Post 52687707)
