ceramic dual ball bearings vs stainless steel ball bearings
does anyone know the difference between dual ball bearing turbos that use ceramic ball bearings and those that use stainless steel ball bearings?
there is not any info on this subject that I can find.
also, this is not a thread about "is ball bearing better than journal bearing", so let's not get started with all that
thanks.
thanks.
Moderator
Re: ceramic dual ball bearings vs stainless steel ball bearings (pimpintyperintegra)
I'm not going to get into a lot of detail, but what I can tell you is that the use of ceramic bearings in turbos is very 80s technology, before there were steel ball-bearings. I remember when RAYJAY turbos used to use them, and (unfortunately) Turbonetics on some of their street series had a tendency to use them as well. The ceramic bearings could take the heat of the steel ones, but they were a bit more fragile when it came to abuse over the long haul than today's better equipped steel-ballbearing setup. IT's one of those things in which it's not the worse thing in the world to own if you happen to have it, but it's not something you want to choose when there are so many other alternatives out there. I honestly would use a standard 360 degree journal bearing than a ceramic bearing turbo.
I've used them, liked them for what they were, and moved on.. It's like using Windows 98.. sure it'll work, but it can't support a lot of new things that are out there.
so why is the price for the ITS dual ball bearing cartridges so expensive? i did a search for ceramic ballbearings vs steel ball bearings, the ceramic wins hands down
Moderator
Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude »</TD></TR><TR><TD CLASS="quote">so why is the price for the ITS dual ball bearing cartridges so expensive? i did a search for ceramic ballbearings vs steel ball bearings, the ceramic wins hands down</TD></TR></TABLE>
If you say so..
If you say so..
Re: (coocoo32)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coocoo32 »</TD></TR><TR><TD CLASS="quote">Yello...</TD></TR></TABLE>
yes they are really ceramic
Re: (EnFOURcer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EnFOURcer »</TD></TR><TR><TD CLASS="quote">The ITS dual ball bearing cartidges are similar to the Garret.
They are VERY durable and efficient. </TD></TR></TABLE>
this is good...because I just got an ITS turbo
s1ngle
29
05-09-2012 03:48 PM
MadVTI
10-04-2009 05:47 PM
TB123
Transmission & Drivetrain
11
04-12-2009 11:06 PM
