Catch Can Line Options
right now on my catch can i'm using the clear hose with the white mesh running through it. The lines look like hell though from all the crap going through it. Anyone know of any other hose i can use ? i noticed that some spots on my current hose look a little melted so i guess it would need to withstand high under hood temps. thanks in advance
Re: Catch Can Line Options (GoFastTshirts.com)
ps line will work
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunslinger »</TD></TR><TR><TD CLASS="quote">ps line will work </TD></TR></TABLE>
That would work out fine, assuming you require something for a barbed fitting. Otherwise i like stainless flex line w/ an pipe fittings. |
good info thanks
Re: Catch Can Line Options (ForceFed_Motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed_Motorsports »</TD></TR><TR><TD CLASS="quote">
That would work out fine, assuming you require something for a barbed fitting. Otherwise i like stainless flex line w/ an pipe fittings.</TD></TR></TABLE> well if he has clear braided hose I doubt he is using anything but barb fittings |
