Catch can - I searched and didn't find anything on this type!
I have a Eurospeed Racing oil catch can. It has only one port in and a breather on the top. Can I use this on my B16 turbo? It's a high horsepower build-up. If I can, how would I hook this one up. When I search I found many diagrams on installing the two port can styles but never a single port.
I have the black box in the back of my motor which goes up to the PCV nipple and also the nipple on my valve cover? Do I tee them together in to that one port???
Any help is appreciated.
Re: Catch can - I searched and didn't find anything on this type! (B16A1-EF9)
Well I hooked mine into where the black box on the back of the block is. 1st thing I did is there is a hose fitting near the top of the block just below the head that a hose comes out of and goes directly into the top of the "black box" I tapped this out to 1/4 npt and got fittings and hose and ran it to the upper port on the breather and the bottom drain on the breather you have you will need to take out the drain and it should be like 3/8 npt and get fittings for that to go to the back of the block where the big hole is that the black box drains into. Now that big hole has to be plugged, I had a machinist turn out an alluminum plug with a .002 interferance fit and it had a 1/2 npt drilled and tapped in the center for the breather to drain into.
sorry not the best pic but all I have
wtsapexipowerfc
11-18-2010 09:47 AM
efjones9
04-20-2009 09:01 AM
