catalytic converter fouled?
New User
Anyone here foul their cat by running too rich for too long or burning oil?
If so, how fast can it happen and is there a good way to test for it?
Re: catalytic converter fouled? (GruvyTune)
My friend's cat bought the farm after running really rich with the JRSC for about a year. Symptoms included:
1) BOV like sounds around 4500 when shifting
2) General lack of power
3) Bad gas mileage
4) Got passed by Geo Metro. See #2.
When we took the cat off, we held it up to the sun and couldn't see anything! A piece of the honeycomb had busted loose and the thing looked totally plugged.
Sonny
3) Bad gas mileage
Sonny
If you had a temp gun, you could take the inlet and outlet temps. Outlet should be ~100 dgr F higher.
If you had a scope or meter, you could look at the 2nd O2's output. While cruising around, it should stay up at about .7-.8V. On a decel condition, it should drive lean. Since the Catalytic Converter uses O2 to do its job, if you show lean when cruising, you've probably found your culprit.
New User
Re: catalytic converter fouled? (EE_Chris)
that would be all easy except its an obd1 car and has only an inlet o2 sensor!
Its a carsound hi flow cat so i didn't know if perhaps it was less likely to plug up than the stocker.
New User
Re: catalytic converter fouled? (97CivicFerio)
Ahhh, just take a broom handle to it man! HEHE
92civicfreak
50
12-03-2007 03:03 PM
