Car wont start...running really rich...help
Well today I stalled out getting used to my new clutch, and the car wouldnt start afterwards. It backfired a few times really bad when I tried to give it some gas when I tried to start it. You can really smell alot of fuel. It was running extremely rich from the start and I never really got on it, just waiting to dyno next week. Im thinking I should pull the plugs and clean them up a little to get her started, what do you guys think ?
Re: Car wont start...running really rich...help (C-Redrum)
If you are running that rich, cleaning the plugs wont make any difference. Your going to foul them out again. If you are running that rich, I dont think that you'll be able to get the car to dyno if you plan on driving it.
Re: Car wont start...running really rich...help (boosted hybrid)
well see, the thing is, I was able to drive my car about 100 miles from the shop to my house, then a few more around town, so wouldn't you think if I clean them, I can get to the dyno ?
What should I use to clean them anyways, some said brake cleaner (don't call me a dumbass if its not the right thing to use, I post here to learn...)
Guest
Posts: n/a
you coould just pull the plugs, clamp off the fuel supply and turn the engine over a few times to get the excess gas out of the cylinders, them put the plugs back in and try to start it with the fuel clamped off first, then unclamp it and try starting it.... sounds confusing, but's it's pretty simple and has worked for me before
Re: Car wont start...running really rich...help (EX-Boosted97Lude)
hmm...how do I clamp it...Also, do you think I could run with my stock ECU for a little (I have 72lb/hr injectors and GM 3bar...) ?
The torch will burn off the crap on the spark plug. The combustion chamber is far hotter than what an open flame can produce on the spark plug. I have always cleaned my spark plugs that way.
make sure you buy a new set of plugs to take to the dyno. Once you get it leaned out a little your going to want to put some fresh plugs in to finish the tuning..
Re: Car wont start...running really rich...help (BoostedSi)
crazy man... stock ecu with 85lbs injectors?? i couldn't even run my stock ecu with 550's when i had my hondata problem.. crazy
Re: Car wont start...running really rich...help (accordfreak)
stock ecu wouldnt idle of course with 550s. 85lb with 3bar will idle and drive. Trust me...i've done it so have others.
yeah haha i was just reading about it on your other thread " HELP! think my aem took a **** on me. stock ecu+880s=starts?!!"
i think my gm 3 bar map sensor is bad cuz i tried starting with the stock ecu, 550s, and the 3 bar map.. ohwell
gotta find another 3 bar map sensor...
Re: Car wont start...running really rich...help (b16ahybrid)
hmm. I gotta figure out what kinda plugs I have in my car..I can read the NGK part # on the plug right ?
judging on your sig t3/t04e h22 and you also stateing that your not sure what plug i would think you didnt change your plugs with that set up??????if not try bcp7es-11 gap at 30 i got same set up or could just be a bad start up program in you stand alone
