car governs at 3k, as soon as boost starts to build help!
Okay so i fully put a turbo kit in my car and when i drive it it always governs at 3k, i can not seem to get over 3k. Now my friend said i need to put a check valve in before the map sensor so i put one in and made no difference. I can not seem to get my car into boost. Does anyone have any idea why my car would govern at 3k. Im pretty sure i put the check valve in properly, it stops air from going into the map sensor but allows air going out. right? I purchased one of those really exspensive ones but they havent come in yet so i just got a cheak $4 from advance to see if it works., I got the basemap off of http://www.xenocron.com/ and the basemap i got for turboedit is ng48-PR4tune-19.bin and i changed the fi's to 240cc which is what mine are stock. Anyone have any ideas? Thanks, Jim
Re: car governs at 3k, as soon as boost starts to build help! (90AcuraIntegra04)
sounds like ur crank angle sensor in ur distro is bad.And u should be getting better managment then a check valve.
Re: car governs at 3k, as soon as boost starts to build help! (93supercoupe)
sorry, didnt see the last part.
Check ur crank angle sensor in ur ditributor
one time before i had my vafc/ jackson racing fmu i put one of those racing chips in my ecu it governed at 3k.... what do you have for engine management?? it might also be getting too much fuel and its cutting off
You might need more than one check valve. My old drag kit came with 5 I think.
i put a zif socket in my ecu and i have 30 chips and a burner next to me so i can burn chips and put them in within a minute. What would i change in turboedit in order to trick my map sensor. I have a missing link check valve comming in but if i dont need it ill sell it. Thanks
just to clarify, you didn't put the check valve in line right ? you put it using a Tee correct ? also one, didn't work for me try using 3. This is just a band aid, i hope you plan on using a engine management system
Re: (90AcuraIntegra04)
i have four check valves on my car one tees of to the other and soo on then goes to my fmu
are you using a chip for your engine management or something like hondata/crome
if u are running turbo edit, u DONT use check valves.
Put the stock ECU in the car and stock injectors.Get rid of ALL the check engine lights, then re-instal ur chipped ecu and find a suitable basemap.
U dont use check valves if are running turbo edit
Re: (exotik4doorcivic)
The check valves are made to bleed of boost so the map sensor does not sense boost. If its run inline, it can bleed off the boost. Also if its run in line, the car will boost and push against the check valve and keep it closed so the mao wont be able to read vacum at all and make the car run bad....or not at all like a limp mode
take the valve out, reset the ecu and find a good base map, granted u have no major CELs.
I cant figure out why u guys are still talking about this stupid check valve.
Take it OUT
Take it OUT
Re: (93supercoupe)
I cant figure out why i have a solid light on my ecu. I put the zif in 100% perfect, i had one chip making it blink 13 times and the rest are keepin it solid. Where can i find a good basemap? Thanks
