Can't find head gasket that holds 15psi, help me
Hello folks wassup does anybody know of a GOOD quality head gasket for my d16y8 that won't crap out on me like the stock ones do? Please don't suggest O-ringing the head to the block because i don't have that cash or time just tell if u know of a real good head gasket for turbo hondas except the GReddy one i need one for stock thickness or thinner, thanks
Re: Can't find head gasket that holds 15psi, help me (maddskilzz)
Call up race engineering and see if cometic makes a gasket for that perticular engine...
Other that that I don't know unless inline pro has something for you...
Adi
The stock headgasket should be more then enough for you. Your problem seems to be in your tuning. I have a buddy with the same motor and similar mods that runs 20psi on the stock headgasket. He has been running like this for 2 years now without a headgasket problem. Another thing you can do is replace your headstuds/bolts with ARP headstuds. You probably have a couple stretched headstuds from when you lifted the head during one of your previous headgasket problems. Start with your headstuds if your tuning is on point. But I guaranntee the headgasket is not your problem.
stock OEM headgaskets can withstand 500hp easy as long as your motor is tuned to handle it.
New User
hmmm...i know of at least 2 600hp Hondas using stock head gaskets. One must wonder why yours won't hold....
Re: Can't find head gasket that holds 15psi, help me (VaporTrail)
if the stock head gaskets can hold 500+ hp, then, do i really need to get a thicker gasket like the one's by inline pro? i know it lowers compression, so are thicker ones to help reduce stress on the pistons, rods etc? i'm still new to this so just trying to gather as much info as possible.
nyte_rider
Honda Civic (2001 - 2005)
05-19-2008 08:48 PM
