Can you use a GSR JRSC on a 00 Si?
I know most parts swap between the two. Will it fit? If so, what needs to be modded to make it work? Alot of GSR kits for sale, but no Si kits I can see.
TIA
Chris
TIA
Chris
Mr. Badwrench
Re: Can you use a GSR JRSC on a 00 Si? (bonylad)
one for a type r should work, the manifold flange is different on a gsr and si. the si should be the same as the type r. according to out hondata gasket invintory, the c5 and the b16a are the same p/n.
It will work, you just have to be handy with a drill. The castings are the same and the lower bolt holes are the same, just the upper bolt holes and the water port need to be drilled out, then the water port needs to be tapped. It takes me about an hour to do one, and I've done several. I currently run a B16 manifold on my GSR head with no problems. Here's a pic of another one that I did:
If you're really interested in a JRSC kit, then please check out the one I'm selling now. It's originally for a ITR and should fit right on your B16.
http://cgi.ebay.com/ebaymotors...20793
Re: Can you use a GSR JRSC on a 00 Si? (rmcdaniels)
B16A head and ITR are the same bolt pattern. GSR is the odd one.
B16A, ITR, GSR all use the same parts except the manifold.
1 Post
Re: (StylishDOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StylishDOHC »</TD></TR><TR><TD CLASS="quote">jackson superchargers are intergrated as part of the intake manifold so no, it won't work unless you want to swap to a 94+ GS-R head.....</TD></TR></TABLE>The mani & the blower are separate. Either change the mani or the head. They are not intergrated together.
Re: (G"UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G"UNIT »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
that was helpful
that was helpful
1 Post
Re: (4rc-fed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4rc-fed »</TD></TR><TR><TD CLASS="quote">
that was helpful </TD></TR></TABLE> Is there something I missed? Sorry, no comprende.
jdmhatch94
02-27-2003 08:38 AM
