Can you have a super rich A/F ratio and still ping (detonate) w/ too much timing?
because if your wideband is telling you you're fine, can you still blow your motor w/ too much advance? Or is A/F ratio also a measure of correct timing...I doubt it...
Re: Can you have a super rich A/F ratio and still ping (detonate) w/ too much timing? (D16A6Turbo)
This is a very good question.... I want to know the answer to this one too. I belive you are right tho. If your AR is find but you advance too much you can still detonate. But for some reason, I also know that timing also affects if your air/fuel mixture burns slower or quicker between the power stroke and the exhaust stroke, so if timing is set so that not all the fuel burns up, you'd get a richer (lower) reading on the sensor cuz more fuel is in the exhaust pipe. It's a weird thing. Also, keep in mind that timing also affects exhaust temp and some people say they can tune with a exhaust temp guage just as well as having a wideband. I think this would be false due to the temp also changing with timing. So now it's 2 variables affecting the exhaust temp.
I definatly want to know the answer to this one... Common tuners... show us!
Re: Can you have a super rich A/F ratio and still ping (JRSCCivic98)
the reason I ask is because to safeguard yourself against any kind of engine failure would not exclusively be to analyze A/F ratio via a wideband, but also tuning w/ a knock sensor as well...
hey, that brings up another point...could you primarily safeguard yourself w/ only a knock sensor because it would detect detonation whether it is in the form of:
1. Lean A/F
2. Too much timing (could a wideband pick this up?)
3. Bad octane (could a wideband pick this up?)
4. Too hot a plug (could a wideband pick this up?)
If this is the case, wideband tuning leads me to think that you're only halfway there...hope I'm wrong...
1. Lean A/F
1 Post
Re: Can you have a super rich A/F ratio and still ping (D16A6Turbo)
1. Lean A/F
1. Lean A/F
When I bought the Link ECU from my tuner, he said that I must buy these two additional meters as a safety precaution in the event that the injector(s) fail or my engine starts pinging badly... They may be ugly, but I must admit, there have been several occasions when either my A/F has been in the red zone (lean) under WOT or the huge red high-intensity LED on my knocklink meter has flashed at me letting me know that i've been pinging and that something's not quite right..
I praise the KnockLink meter the most though.. since I still have my EGT gauge to look at if my AF meter (LambdaLink) isn't working properly (which it never has)
found this for ya. http://sandstallion.com/link.html
didn't see any pricing
New User
Re: Can you have a super rich A/F ratio and still ping (ModAddict)
