can u make good hp with a pinned block being ls/vtec boost
Old 01-26-2005, 06:37 AM
spoon23_JDizM AkA SpOoN20's Avatar
Default can u make good hp with a pinned block being ls/vtec boost
well heres the block,and i plan on throwing 84.5 mm eagle sleeves with 9.1 pistons and some h-beams...but heres the work and tell me if it looks ok to be raced at 25lbs once in a while and 7lbs everyday
Old 01-26-2005, 07:12 AM
Rod.'s Avatar
Default Re: can u make good hp with a pinned block being ls/vtec boost (spoon20)
you cant just look at a block and say how much boost it can take.
Old 01-26-2005, 09:46 AM
tgreaves's Avatar
Default Re: can u make good hp with a pinned block being ls/vtec boost (redturbocivic)
I would say you could run 40psi on that block......With a little tiny greddy turbo.. Why not ask how much power do we think you can run throught the block..
Since there are alot of 300-400 hp setups running on stock sleeves I would say you could do that..
Old 01-26-2005, 09:48 AM
DaX
DaX's Avatar
Whoa! Pinned block is teh 0ld sk3wl!
Old 01-26-2005, 10:47 AM
I'm a Jackass
Slimm-rw-'s Avatar
Default Re: (DaX)
pinned block IS da old skool
Old 01-27-2005, 06:51 AM
Default Re: (Slimm-rw-)
anymore info?
Old 01-27-2005, 10:01 AM
mrspeaker's Avatar
Default Re: (spoon20)
What does pinned block mean..??
Is it reffering to those cylinders around the cylinder walls??
Old 01-27-2005, 11:44 AM
mrbsponge's Avatar
[QUOTE=spoon20]well heres the block,and i plan on throwing 84.5 mm eagle sleeves with 9.1 pistons and some h-beams...but heres the work and tell me if it looks ok to be raced at 25lbs once in a while and 7lbs everyday[QUOTE=spoon20]
the ONLY place you should THROW this thing is in the dumpster
Old 01-27-2005, 11:45 AM
Default Re: (mrspeaker)
Old 01-27-2005, 11:47 AM
mrbsponge's Avatar
dude that is mad old and has been proven to hold YES, but cool and be efficient and last, NO. thats the reason we stopped doing this like 4 years ago
Old 01-28-2005, 06:34 AM
Default Re: (mrbsponge)
so it will not last if i'm running eagle sleeves in there with upgraded pistons and rods?
Old 01-28-2005, 06:58 AM
Blackack26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon20 &raquo;</TD></TR><TR><TD CLASS="quote">so it will not last if i'm running eagle sleeves in there with upgraded pistons and rods?</TD></TR></TABLE>
If you get the block sleeved I don't see why you would even need the pins.
The question you asked is kinda confusing... Do you want to run all that boost now? with the stock sleeves and pins? Why not wait until you get it sleeved?
Old 01-28-2005, 05:00 PM
Default Re: (Blackack26)
NO i'm gonna be running 7lbs on my stock block,this block pictured is a potential block that i can buy fairly cheap,so my question was that if i get this block the way it is and sleeve it up with some eagles and pistons-rods can it handle 500 plus?
Old 01-28-2005, 07:46 PM
BUMP
Old 01-29-2005, 08:26 AM
one
Old 01-29-2005, 06:36 PM
biggmike2's Avatar
too bad they pinned it in the wrong direction.
looks more like a homemade block guard to me.
Old 01-30-2005, 07:00 AM
b18cls1's Avatar
Default Re: (biggmike2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biggmike2 &raquo;</TD></TR><TR><TD CLASS="quote">too bad they pinned it in the wrong direction.
finally a real pinned block i was waiting for someone to post a pic of a pinned block because that firstone is not.
second if your going to sleeve a block who cares what the cyl look loke they will be gone anyway
Old 01-30-2005, 09:30 AM
mrbsponge's Avatar
they are both "pinned" blocks but the first one at the top was something we use to do back in the day, like 95-98. the ones with the horizontal pins are something that hasnt been done for too long, i know the guys from HMT do it alot, but you has to be conscious of what size bolts or set scres you are using, if you use little ones are they really gonna prevent side loading of the sleeve?? the ones above seem to be like pretty good size bolts.
still for all that work i would rather just install a 60 dollar block guard and ride out.
i have even seen multiple block guards installed!! its ghetto but it worked
Old 01-30-2005, 06:45 PM
b18cls1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">they are both "pinned" blocks but the first one at the top was something we use to do back in the day, like 95-98. the ones with the horizontal pins are something that hasnt been done for too long, i know the guys from HMT do it alot, but you has to be conscious of what size bolts or set scres you are using, if you use little ones are they really gonna prevent side loading of the sleeve?? the ones above seem to be like pretty good size bolts.
i have even seen multiple block guards installed!! its ghetto but it worked</TD></TR></TABLE>
we used to cement the block back in the early 90s
Old 01-30-2005, 07:27 PM
mrbsponge's Avatar
we cemented them on our drag motors only because they didnt run for more than a few seconds, and were alcohol fed so they never even had a chance ot get hot, concrete made them damn near indestructible
Old 01-30-2005, 07:34 PM
b18cls1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">we cemented them on our drag motors only because they didnt run for more than a few seconds, and were alcohol fed so they never even had a chance ot get hot, concrete made them damn near indestructible</TD></TR></TABLE>
yeah we drilled coolant holes after the boiler cement hardend up to get the water to the head , it worked well and thats all we had then..
Old 01-31-2005, 06:33 AM
DaX
DaX's Avatar
Holy ****, that's nuts!
tonys91tegra
07-09-2009 11:07 AM
killacam661
11-26-2007 12:35 PM
tobe1424
08-16-2005 10:11 AM
BOOSTIN1
03-29-2004 11:02 AM
Speed PHreak
12-20-2001 12:51 PM
Quick Reply: can u make good hp with a pinned block being ls/vtec boost
