can someone verify my resistor box install? [pics inside!]
EDIT!!! New set up below, please read and verify for me!
Ok,
here lets try and explain this with pictures!
Ok pictured below is the "dead end" harness. Now, ive checked for continuity and ive found the four pins in the connector that coincide with my four injectors. my wires have a female end on them (ive pulled one out so you can see it). You can see i did not cut or splice any wires.
The next picture shows the OTHER end of the wires i made. this end has a male fitting and will go into the resistor box connector that is also pictured in my hand. the red wire will then go back into the 'dead end' connector in any open hole as the original instructions state.
[img]
http://www.imagestation.com/picture/...7.jpg[/img]
does anyone see this as a problem? checked for continuity this way: Put the female end of the plug into the connector, then put one end of the testor on the injector wire up by my injector clips, and the other end at male fitting and got positive tone on the volt-meter.
Modified by Mr. Vapor at 10:40 PM 4/27/2005
Modified by Mr. Vapor at 10:48 PM 4/27/2005
Modified by Mr. Vapor at 10:53 PM 4/27/2005
Modified by Mr. Vapor at 6:00 PM 5/2/2005
Re: (93turbo16)
and the red wire can go back into any open 12v pin on the connector? doesnt matter which one right, they are all 12v powered?
Re: (Mr. Vapor)
i dont have pictures. but when i did mine i did what you did. and then for the wires left over i just put all those together and hooked it up to the red wire. if you have an old distributor thats messed up you can take the big plug from it and plug it into that big plug with all the wires from the injectors. **** probably doesnt make sense but i hope you get it
Re: can someone verify my resistor box install? [pics inside!] (Mr. Vapor)
finally turning up the boost
Or could have went with RC 750cc's (Saturated) but 90.00 per injector is madd $
Re: can someone verify my resistor box install? [pics inside!] (FredoSP)
ok more questions, issues:
the cap on the dead end side of the dead end connector has what i believe are "bus-bars" which short all the wires in this connector together.
if i dont run this will the connector still be functioning the same way? so that would mean my way wouldnt work sincei need to have the cap on. HOWEVER, if i dont run the cap, how can i get my red wire from my resistor box to any open pin?
Ok, this is the NEW set up:
cut all the injector wires about 3" before the "dead end connector" I took the cut wires, and extended each wire and connected them to the black wires on the box.
the 3" nubs coming out of the connector i soldered all together (four of them) and then put a wire extension on to this and connected it to the red wire coming out of the resistor box.
hope i did it correclty, i went insande reading ladysman's and T-Ro's installs and almost went nutty trying to figure out the best way.
does this sound correct?
T-RO
02-09-2014 07:06 AM
Rus1an
05-18-2007 08:51 AM
RTW DC2R
05-16-2006 05:57 PM
