Can the OEM honda fuel pump provide enough fuel for DSM 450's?
I am going to be running DSM 450's w/ the AFC hack. I have an aftermarket fuel pump (Walbro 255) but I dont have the $$$ to get it installed. My fuel tank needs to be dropped to install it, and I dont feel confortable doing something like that myself. Will my OEM pump be able to provide enough fuel for the injectors, or should I stick with just an FMU till I have the $$$ to have the pump installed?
Re: Can the OEM honda fuel pump provide enough fuel for DSM 450's? (VTEC-DA)
Yes you can.
I guess it really depends on what kind of fuel pressure you plan on running, but you're probably going to run around stock.
stock pump will prvide more than enough for the 450's. with stock everything else, you will run too rich.. that is why you need a way to control the injectors by correcting fuel in the negative direction.
Re: Can the OEM honda fuel pump provide enough fuel for DSM 450's? (wenlyone)
yeah, without a way to control them, you will run so rich the car will bog.
Re: Can the OEM honda fuel pump provide enough fuel for DSM 450's? (KC GSR)
yeah, just use the afc, dsm injectors, and resistors and leave everything else stock
rjardy
10-14-2002 08:15 AM
