can i take a wire wheel to my stock d16y8 pistons
i want to do this so i can get all of the carbon build up off. can i use a wire wheel or is some thing else better? also is it ok to polish the top of them? here are some pics
any info will help!
any info will help!
Re: can i take a wire wheel to my stock d16y8 pistons (CovertFI)
Soak them is some carb cleaner over night...then just rubb them with a cloth.
repeat if neccesary.
As recommended it is best to dissolve the crud away chemically.
The wire wheel if used on the ring area will open up the ring grooves a bit near the edge of the pistion which is sure not optimal.
Remember a little scotch brite work on the piston crowns, no sharp edges and a slight roughness for boundary layer turbulence and a quick fine carbon layer buildup after rebuild.
Regards,
BigMoose
PS: Great look at quench area in action on the piston second from left.
[Modified by BigMoose, 3:49 AM 6/17/2002]
Regards,
BigMoose
i am sorry to ask a newbie question
which part is the piston ring?? is it even on there??
thanks
thanks
Re: can i take a wire wheel to my stock d16y8 pistons (xbird)
(I'm not an *** hole)
The piston ring's are on there. You can get the best pic of the ring's on the second picture.
Imagine the piston as a perfect cylinder. Now look at the "ring's" that are outside the cylinder. Those are the ring's.
from the top of the piston...1st compression ring...2nd compression ring...1st oil ring...2nd oil ring.
Re: can i take a wire wheel to my stock d16y8 pistons (Bryson)
THERE ARE 4 RINGS??
coz i see there is a part which is a little "dirty", and i am pretty sure that's the ring..
but i didn't know there are 4 ?!
Well really it's only consider'd 3 ring's...
2 compression
1 oil
but the oil ring has a top and a bottom ring.
so technically there are 4.
2 compression
1 oil
um, so you don't get blow-by, and burn all your oil, and otherwise have a crappy running(if at all) engine...
D Tranny Guru
use carb cleaner on the tops, then tape the rings off and us a BRASS wire wheel the get the last of the carbon of the piston TOPS.
Re: can i take a wire wheel to my stock d16y8 pistons (Mista Bone)
there is almost nothing on the side near the rings only on top. so i was only going to put the wheel on it.
lvs4rock
Engine Machining & Assembly
03-23-2018 02:14 PM
c.dub
06-22-2006 10:32 PM
