Can I make 400hp on pump gas w/ high compression?
Old 05-31-2005, 09:33 AM
rocket256's Avatar
Default Can I make 400hp on pump gas w/ high compression?
I know you have heard this question time and time again. But I have searched but came up nothing that is in the same category. Im trying to get 400hp. First off I have a: fully built GSR 83mm w/10:1 cr, built head w/ CTR cams, edelbrock man. and just about more stuff then the law will allow! I had a custom Rev Hard kit w/ a SC34 and a 30x8x3.5 FMIC. Now I have some new upgrades. Neukin man, 3" DP, 3" exhaust and a SC61. Can my goal be achieved on pump gas (93 octane) and last longer then a week?
If you have done this drop me your .02$ or is my compression going to be my down fall?
Old 05-31-2005, 09:53 AM
PrecisionH23a's Avatar
Default Re: Can I make 400hp on pump gas w/ high compression? (rocket256)
Yes... just be careful with your ignition values.
Old 05-31-2005, 09:56 AM
Soon_2b_evil's Avatar
we'll see real soon.
Old 05-31-2005, 11:13 AM
cinq's Avatar
I dont see why not. I mean I have a stock GSR block running 11psi=315whp. Lasted about a year before the rindlands gave in. Now..with my new bottom end...
I hope to get around 400+ with pump gas. That's more than I need.
Old 05-31-2005, 11:21 AM
Unsivil_audio's Avatar
EASY, Imo. You have the prime motor to do that with too (once again, IMO). 10:1 should be fun.
Old 05-31-2005, 11:43 AM
seen4ever's Avatar
Default Re: Can I make 400hp on pump gas w/ high compression? (Soon_2b_evil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soon_2b_evil &raquo;</TD></TR><TR><TD CLASS="quote">.</TD></TR></TABLE>
haha, i know the girl in your avatar. I love how that pic was taken off a local forum and now is all over the web.
Old 05-31-2005, 12:58 PM
_entropy's Avatar
Default Re: Can I make 400hp on pump gas w/ high compression? (seen4ever)
I was able to run about 15 psi on my 10:1 motor, so that should take you to 400 WHP with an SC61.
Old 06-01-2005, 07:54 AM
rocket256's Avatar
Default Re: Can I make 400hp on pump gas w/ high compression? (Napoleon Dynamite)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Yes... just be careful with your ignition values.</TD></TR></TABLE>
Is there anything I can do to protect them?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soon_2b_evil &raquo;</TD></TR><TR><TD CLASS="quote">we'll see real soon.</TD></TR></TABLE>
What's your setup? How soon?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Napoleon Dynamite &raquo;</TD></TR><TR><TD CLASS="quote">I was able to run about 15 psi on my 10:1 motor, so that should take you to 400 WHP with an SC61.</TD></TR></TABLE>
What turbo was you using?
You all say that it can be done but; Im just wondering will it be pushing it? I'll be taking it down to Dallas to let <U>Tony1 </U>tune it once again. I know <U>Tony1</U> likes to tune for reliability not Numbers! That's why I like his work.
Old 06-01-2005, 08:22 AM
adseguy's Avatar
The only problem seems to be the compression. It's not a problem really it just requires a GOOD tuner (hell I wouldn't even touch that). If he retards the ignition too much you won't make good power and you EGT's may be too high. minimum best timing is harder to reach on high comrpession motors because the margin between good power and detonation is not wide at all. A simple bad tank of gas, a cold day on warm tune, a hot engine, etc will lead to detonation. So it's up to the tuner to make it safe yet not run excessive retard. That's all. Tony1 has done some good cars and from what I've seen on H-T he is pretty good so I would trust him. DO IT and GL
edit: I would touch that....it's only 10.1 compression. For some reason I tought it was like 11 to 1 . You are fine
Old 06-01-2005, 11:16 AM
mike1114's Avatar
Default Re: Can I make 400hp on pump gas w/ high compression? (adseguy)
I run GSR, 10:1 CR, 348whp/325tq @ 10psi t3/t4e .60/.48, 3.0 dp and exhaust, fully built, FR ramhorn, hondata
I'm almost at 400whp at only 10psi. I'll hit 400 no problem with pump gas!!
Old 06-01-2005, 12:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocket256 &raquo;</TD></TR><TR><TD CLASS="quote">
2.0ltr with SC63 and 10.5compression.
As soon as my AEM CDI kit gets in, im rockin and rollin
Old 06-01-2005, 12:57 PM
wade's Avatar
just scrolling about, and what do i see...
soon2beevil, that avatar is my friend man, cant believe her pic is getting about. she lives in southern indiana, enjoy it i guess
Old 06-01-2005, 01:07 PM
Default Re: Can I make 400hp on pump gas w/ high compression? (wade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade &raquo;</TD></TR><TR><TD CLASS="quote">just scrolling about, and what do i see...
soon2beevil, that avatar is my friend man, cant believe her pic is getting about. she lives in southern indiana, enjoy it i guess </TD></TR></TABLE>
LOL
Old 06-01-2005, 02:08 PM
rocket256's Avatar
As soon as my AEM CDI kit gets in, im rockin and rollin</TD></TR></TABLE>
why the SC63? The SC61 is only rated about 30hp less and not so laggy.
Old 06-01-2005, 03:05 PM
Magnaflow's Avatar
10:1 isnt that high. There was an article in Import Racer last year with an integra with a b16 Head 10:1 Comp ratio (with rods/pistons) and some minor head work. He was putting down 500. I am pretty sure that was on Pump gas...
I will be running 11:1 Compression when I turbo my beast.
Old 06-01-2005, 05:07 PM
tony1's Avatar
Default Re: Can I make 400hp on pump gas w/ high compression? (Magnaflow)
Ok, how bout this one, who has actually done it and not had any problems long term? 11:1 is dumb on pump gas, you'll be very limited by octane. 10:1 is fine, though 400whp on pump is about as far as i'd recommend going. Whatever car that was in a mag, MAY have done 500whp on 93 octane, but not for any length of time at all. I've made 470whp on 91 octane, but I wouldn't recommend it. If you want to make big power on pump gas then 9:1 is the best compression for all around performance.
Old 06-01-2005, 05:28 PM
B18CXr's Avatar
Made 395hp on a dyno jet @ 17ish lbs, 93 pump
9.8:1, stock bore and sleeves
https://honda-tech.com/zerothread?id=1120721
Old 06-03-2005, 10:02 AM
rocket256's Avatar
Default Re: Can I make 400hp on pump gas w/ high compression? (B18CXr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">Made 395hp on a dyno jet @ 17ish lbs, 93 pump
That's some good $h!t. But the t67 is a monster
Old 06-03-2005, 11:45 AM
m R g S r's Avatar
so....?
that only means it takes less boost on the 67 than it will with a smaller one. compression will not like a big turbo better than a small one.....
Old 05-22-2006, 08:46 PM
MilFhunter001's Avatar
LOL</TD></TR></TABLE>
I love that Avatar..nice tittays!..
benjamenenglish
28
03-10-2010 05:25 AM
black0hatch
06-06-2008 06:38 AM
ping83
08-26-2003 07:45 AM
redteg
04-24-2003 07:39 AM
90da4dr
03-07-2003 09:36 PM
Quick Reply: Can I make 400hp on pump gas w/ high compression?
