Calling all -- Greddy Type RS BOV users
what boost are you running? whp?
my numbers are in my sig... and i installed the bov and it doesnt blow off at all. No whoosh sound. it kinda surges then has a long drawn out whistle sound...
any ideas?
only running the one vacuum line...
any ideas?
Re: Calling all -- Greddy Type RS BOV users (Integra21)
i made 567whp. i can't really here mine until im boosting at least 10 lbs . it sounds pretty nice t shhhhhhh . when im boosting 3-5 lbs i cant really hear it!!
im not really sure why you cant hear yours because my cousin one on his y8 single cam and it makes a nice whoossh sound!
Re: Calling all -- Greddy Type RS BOV users (JDMSiGuy17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wideopentuning »</TD></TR><TR><TD CLASS="quote">Hook up both lines and you will be happy it. It will blow off clean and crisp.</TD></TR></TABLE>
i only have the one vacuum line - there is another hole in the back - but there is no way any line can be connected to it
-- looks like ill have to wait a little to install again when i up the boost a little
Who is Mr Robot?
weird. they didnt drill and tap it.
if you can, dissaemble it. brill a hole and tap it for 1/8npt. put a nipple on it and then tap into the charge pipe BEFORE THE THROTTLE BODY.the vacuum in the intake manifold plus the boost in the charge pipe will cause the valve to open quicker and sooner.
so the boost pressure would be pushing the valve up at the same time vacuum is pulling it
Re: Calling all -- Greddy Type RS BOV users (wantboost)
the thing is it make zero sound other than a surge sound during shifts etc..
i do not believe it is blowing off at all
Who is Mr Robot?
it wont sound like the type-s exactly. the discharge is different, but its working. it just sounds like a rush of air.. search through the sponsors fi section, there is a sound clip of one
i know exactly what it sounds like - i have 2 vids saved on my comp.
There is NO rush of air from my bov! thats the problem...
B A N N E D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra21 »</TD></TR><TR><TD CLASS="quote">i know exactly what it sounds like - i have 2 vids saved on my comp.
There is NO rush of air from my bov! thats the problem...</TD></TR></TABLE>
loosen the adj. nut on top and back the threads out on the screw all the way until it's as loose at it will get without coming out. see if it works then. if not, you may need to take the spring out and cut a half a coil off of it. then see how it works. if you need to cut more off, just cut a half of a coil at a time so that you don't over do it all at once.
Who is Mr Robot?
Re: Calling all -- Greddy Type RS BOV users (therealPROJEKTEG)
loosen the adjustment bolt... also remember this, the evo runs about 19psi. you are running 7.
