built 1.92L LSVtec Evans tuned 419hp/312tq
the tq is on the dyno graph. its just light blue hard to see.
3-4hrs of tuning from Jeff Evans. He made 419hp/312tq on my setup with pump gas. this is with only 15psi with the sc6152e
Benson Sleeve B18b
83mm bore
9:1 CP Pistons
Eagle Rods
ACL bearling
balance and polished crankshaft
Golden Eagle LSVtec Conversion Kit
Golden Eagle GSR Head Studs
Z10 catchcan Kit
B16a 2nd gen Head
SuperTech Valve tran
ITR Cams
BDL cam gears
Hondata Intake Manifold Gasket
AEBS intake manifold
.043" Copper O ring Exhaust gasket
RDL Ramhorn
38mm wastegate
3" dp
3" Exhaust with magnaflow muffler
SC6152e
precision 750hp intercooler
Precision 1000cc injectors
gm 3 bar map
Greddy profec B spec 2 EBC
short clip of the dyno run
Modified by komat at 10:08 PM 6/19/2006
Benson Sleeve B18b
83mm bore
9:1 CP Pistons
Eagle Rods
ACL bearling
Z10 catchcan Kit
B16a 2nd gen Head
ITR Cams
BDL cam gears
RDL Ramhorn
38mm wastegate
3" dp
SC6152e
gm 3 bar map
Re: (erebunicrx)
its a daily driver beater. also i believe it was coming close to the limit of pump gas? we had it up to 436 for couple of runs but detune it back down to 419
as for people saying that you can touch the intake manifold with the hondata intake gasket.... they are full of crap. my is just as hot without the gasket
Re: built 1.92L LSVtec Evans tuned 419hp/312tq (Turbocivic94)
couldnt afford it.
i spend $150 in gas money towing the car up to evans. its a 5hr driven each way for me to evans.
i still need to upgrade the stock brakes and struts to something bigger and stiffer
HELLO,GOOD MORNIN'
Re: (STD ONEpointSIX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STD ONEpointSIX »</TD></TR><TR><TD CLASS="quote">nice numbers wheres the race gas / 30psi tune??</TD></TR></TABLE>
daily driver
daily driver
Re: (komat)
nice man. jeff and andrea are two standup people. I always have good times when we run into each other at the track, some day I will be UN broke and compete against them
Re: (wade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade »</TD></TR><TR><TD CLASS="quote">nice man. jeff and andrea are two standup people. I always have good times when we run into each other at the track, some day I will be UN broke and compete against them </TD></TR></TABLE>
yep, jeff answered all my stupid questions while he was tuning my car.
Re: (urnotfast)
good s@#$ with an sc61 i got the same turbo but made 600 on race gas and im goin next week for the retune to push the turbo to the limits.
