Building h22 turbo, compression/headwork/piston questions inside....
Want to build a motor with Benson sleeves Earl gave me some insight and now I have some quesitons for u guys.
Ok so I've decided on a setup that includes:
Benson sleeves 89mm bore
9:1 compression CP pistons
Eagle Rods already from NA setup (these good for about 500whp?)
1mm oversize valves
LoveFabs manifold
Questions:
Opening up combusiton chamber to 89mm would lower compression by how much?
1mm oversize valves won't intefere with each other with stock cams?
And what kinda turbo would u match this setup with? (yes Power is good)
Your questions and comments are appreciated as I have just started research on turbocharging my car. Thx in advance
Modified by 96SR-V at 12:23 AM 2/5/2004
1mm oversize valves
LoveFabs manifold
Questions:
96SR-V
02-05-2004 04:19 PM
