Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   Build recommendations (https://honda-tech.com/forums/forced-induction-16/build-recommendations-3382558/)
Gray95cx Sep 29, 2025 07:17 AM
Hey guys I’m new to the whole turbo engine builds and wanted some advice from someone more knowledgeable than me. I have a b18c1 block that needs to be re sleeved and I’m going to go with the darton mid sleeves to std bore. I have a set of 81.02mm (std bore?) supertech 9.6:1 pistons and supertech h beam rods. I’m going to be getting a b18 crank and a b16 head here in a couple of weeks. I don’t know what cams, valves, turbo, and injectors im going to go with yet so if anyone has any recommendations or suggestions it would be greatly appreciated. Also I don’t know if I should go stand alone ecu or just do a s300 v3.
