buddy club spec III and spec III + good or not for boost engine
buddy club spec III and spec III + good or not for boost engine...
just want to know if they are good or not for supercharge engine...
link:http://www.inlinefour.com/budclubracsp5.html
link:http://cgi.ebay.com/ebaymotors/BUDDY...QQcmdZViewItem
what do you think...thks
...wow.
ok... usually those cams dont work all that well for boosted applications, there was a thread a ways back talking of some big gains using some all motor cams, however, on a s/c i doubt ud be pushing enough boost to make up for the lack of compression needed to make those cams work well.
Re: (LSTEG96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 »</TD></TR><TR><TD CLASS="quote">...wow.
ok... usually those cams dont work all that well for boosted applications, there was a thread a ways back talking of some big gains using some all motor cams, however, on a s/c i doubt ud be pushing enough boost to make up for the lack of compression needed to make those cams work well. </TD></TR></TABLE>
any amount of boost is going to be more compression than an NA motor. I say try them.. everybody is on this "only ctr cams are good for boost" bandwagon... but if you notice, most aftermarekt turbo cams that arent stage 1 are as big as large NA cams (lift AND DURATION). you might need to dial a bit of overlap out, but maybe not.
