What should i watch out for when using ZEX???
New User
i have a pretty stock engine just intake and exhaust
what do i have to watch out for???
any suggestions
how many times before my engine blows???
any suggestions
Re: What should i watch out for when using ZEX??? (soler)
Just retard your timing and upgrade your fuel pump and you should be fine. Do not hit the NOS every stop light and things will go better!
There is no set limit till your engine blows! it all depands on tuning and use! Use your head and the engine should last a long time!
you don't need to retard timing or get injectors with the 55 shot. It comes with a chart. at 65 shot retard 2 deg, 75 shot retard 4 and get a fuel pump. I just played it safe and stuck with the 55 shot. HTH, -C
New User
Re: What should i watch out for when using ZEX??? (TypeC)
More questions:
Is it okay to leave the bottle open all the time? I assume there's a valve near the bottle.
How exactly does the purple box work? Does it trick the fuel pressure regulator into raising the fuel rail pressure?
If you hit the rev limiter, the ECU will cut fuel, right? Won't this cause an extreme lean condition and detonate the engine?
