bout to boost b18c1...last minute questions
Old 12-10-2004, 09:33 PM
a1320addict's Avatar
Default bout to boost b18c1...last minute questions
whats good...bout to throw the xs engineering kit on my stock b18c1
going to get a compression test...only 40k on the motor....tell me something
the xs kit is very complete, and will have a pretuned apexi power fc controlling all engine paramters
just looking for a solid 7 psi ....nothing more
will my stock internals hold up ok? eveyrhting will be fine tuned for maximum reliabily and driveability....but want to know if it is in all honesty a must to build the motor for such a basic boost
Old 12-10-2004, 11:03 PM
Moderator
TheShodan's Avatar
Default Re: bout to boost b18c1...last minute questions (yehiknowrite)
You'll be fine at that pressure w/ stock internals. The POWER FC is a great tool to use from XS Engineering. I'm using the HKS 3037 w/ Power FC, and it is absolutely FANTASTIC.
I've used those kits before, and i truely believe they are wonderful
Old 12-11-2004, 05:06 PM
Default Re: bout to boost b18c1...last minute questions (TheShodan)
awesome...once again shodon...you have pulled through again
you always seem to have helpful insight and post on my topics...thank you man
what kind of car do you have and what are you running?
Old 12-12-2004, 11:29 AM
Moderator
TheShodan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yehiknowrite &raquo;</TD></TR><TR><TD CLASS="quote">awesome...once again shodon...you have pulled through again
Thanks. I try as much as possible. The main honda I'm running is a 1998 DC2 w/ an HKS 3037 Turbo, 850cc Siemen Deka Injectors, Fully Built 9.4:1 GS-R block w/ 81.5mm JE Pistons, Eagle Rods GE HD sleeved. Being installed now is a KAAZ LSD, running a B16B Power FC w/ Boost kit... It's not bad, actually.
Next is an EVO VIII.
Old 12-12-2004, 01:00 PM
dunkd's Avatar
you will be fine... u could probably be safe going with a little bit more boost than that too...
Old 12-12-2004, 02:44 PM
Boostage's Avatar
Default Re: (dunkd)
7psi doesnt mean anything, you can pull timing and add fuel all day long while running 15psi.
Old 12-12-2004, 05:14 PM
Default Re: (Boostage)
well im new to the world of boost.....i just want something very reliable....its all about the power to weight ratio
93GS-TypeR
05-15-2008 06:52 AM
Andy Hatchback
03-25-2008 12:22 PM
Doostur
07-28-2007 07:47 PM
mybarra
04-02-2004 12:28 AM
GroundZer0 336
07-13-2003 07:15 PM
Quick Reply: bout to boost b18c1...last minute questions
