bought a civic turbo. having problems. please help!
hey guys i just sighed up today. i bought a civic hatch d16 turbo last night. drove it for about an hour. when i got out of it i left the motor running and i heard a tap from under the valve cover. the guy said he just built the car 1500 miles ago. all new bottom end and all. the engine seems to miss when i get into higher rpms. my friend says its leaning out. how would i fix that.? then today i hit it a little too hard driving it home and all of a sudden i lost my boost. i feel like im a little over my head but if i could get some guidence i think i can manage. iv owned turbo deisels before but never a turbo gas car. so if anyone could help i would be forever in your debt
Thanks guys. -Doc |
Re: bought a civic turbo. having problems. please help!
what is the setup on the vehicle?
can you post a video? can you return the car and get your money back? so many questions but not enough info from you |
Originally Posted by justYncredible
(Post 50984536)
can you post a video? can you return the car and get your money back? so many questions but not enough info from you Caring for a turbo diesel has little difference to that of a turbo gasoline one. Maintaining them is about the same |
I dont believe i can get my money back. and i dont know much about the setup. the guy gave me a ride in it and i really liked it so i bought it. i can post a video as soon as my phoe is charged. there are also packages of parts in the hatch i can post.
Check for boost leaks, probably blew a boost hose off if you don't think the motor is blown.
i really dont know mch about them either. i had a 5.9 litre cummins. i replaced the turbo at one time and i built the downpipe myself. but other than that i dont have any expirience. i really like the car though amd want to build it if i have to or fix it if its broken. ill post a video and pics soom .
Also. On the turbo going out. I removed the air cleaner and felt for play in the shaft. It was like new. Looked for turbo hoses that may be disconnected and I couldn't find any
Those boxes are not going to help you identify your problem.
It sounds like you lost compression. Either popped a boost hose or blew your motor. |
It runs as if it was a stock non turbo. Is there somewhere specific I should look for a blown hose? Because I looked and there didn't seem to be any disconnectex
if the car sounds and runs fine, then you blew a charge pipe (intake pipe inbetween turbo and intake manifold)
it should be very obvious.... text the guy you bought it from. if hes close, maybe he can help you, but its a common thing. |
Thanks buddy
