Boosting too high
I just installed a greddy kit and everything looks good all the hose and line are plugged in, but when i floor it the boost gauge goes all the way up to like 15, 20 psi. What is wrong cause i never messed with the factory boost level.
Re: Boosting too high (JuuKe_EM)
could be a bad wastgate, or the adjustment of the wastegate is off..
what kit exactly? Whats ur set up? Can u send us pic of the turbo/engine bay?
Re: Boosting too high (FredoSP)
its a greddy tdo5 kit for a 97 GSR. my engine is just stock so i'm scared to blow it
but then when i rev it it only goes to 7psi so i don't know whats wrong
che k your wastegate vacumm line. where did u hook it up to? u shouldnt be boosting when reving in neutral.
dont boost it!!!!!!!
untill you figure out whats wrong |
it is either something is wrong with the wastegate or what i reall thing happened is one of the lines has been ran wrong. Just double check the wastegate lines.
Re: Boosting too high (hollaback6)
where does the waste gate line connect to? i connect it to the regulator. Is that wrong?
