boosting my stock civic need help!!!!
so what is on my car is........aem intake, dc headers, 2.25 piping, exhaust....
i am trying to boost my stock civic with about 7-8psi....i just dont want my motor to blow...so what can i do? i am trying to find 450cc injectors and a resisitor box and retune my ecu... im getting a HMT kit and its a tdo5h turbo i just dont want my motor to blow so can u guys help me and see to it that it doesnt? |
Re: boosting my stock civic need help!!!!
you need an engine management and take it to a tuner and have it tuned after u install the turbo kit.
like do u mean get my ecu redone? i have no knowledge or understanding of it when u say fuel management...
do u mean redo my ecu and put turbo on the map with my d16 map? |
like u need a ecu system such as Hondata,neptune,ectune,aem etc.
check the faq thread lots of good info
https://honda-tech.com/forums/forced-induction-16/%2A%2A%2Aforced-induction-forum-faq%2A%2A%2A-1024174/ |
Originally Posted by jdm inc
(Post 40964126)
do u kno wat kind of system it is.
(Post 40967121)
its a volvo tdo5h |
What kind of ecu chipping/tuning do u have? I think is what jdm inc was asking
yea, good engine management, and a good tune will do the trick
You can get arp's, fresh headgasket, oil/boost gauges, shimmed oil pump, decent street tune for $200, and deal with all the other issues from someone else's hmt kit all for about 175hp...
Or spend about $1500 for an LS/vtec swap. HMT kits are only for people that can diagnose and fix their own problems, not for turbo n00bs like you. No offence, but it would not be a good plan for you to boost your motor "on the cheap". |
Originally Posted by civic_r87111
(Post 40968109)
it was done by a friend so im not sure.. i do know i have launch control and d16 base map |
Originally Posted by HiProfile
(Post 40969542)
Or spend about $1500 for an LS/vtec swap. HMT kits are only for people that can diagnose and fix their own problems, not for turbo n00bs like you. No offence, but it would not be a good plan for you to boost your motor "on the cheap". if i take my turbo out for smog and put it back after with the same ecu i should b fine right? or do i need to get it retuned again??? |
you need to do a lot more research before you turbo your car its not something that ya just jump into without having a lot more info than you currently have.
^^ x2
