Boostedjd's Prospective GS-R turbocharger build thread
#76
Re: Boostedjd's Prospective GS-R turbocharger build thread
Autometer makes this hut its only in black and my interior is grey
glowshift makes this that comes in grey but id need a third gauge
but thinking his might be my best bet, keep it as stock looking as possible and no real cutting of the dash ( i dont think) who needs a clock anyway. Anyone ran this?
#77
The stock ECU doesn't have an oil pressure input - the stock sensor only triggers the dummy light.
I'm using a GlowShift triple pod A-pillar. The color match is decent, and the fit was ok. The GlowShift pod does match my interior color decently, but it is painted and not molded in this color - if you're not careful, you can scratch the paint off and see the black plastic underneath. It didn't fit over my stock trim piece very well, so I ended up cutting my stock trim piece and only keeping the portion that goes over the door, and enough length to tuck behind the GlowShift pod. I kind of hate that I had to cut a good piece of ineterior trim, but oh well. The screws and caps that came with it sucked, so I threw those away and just opted to use a single interior Honda screw to hold the pod to the A-pillar.
I looked at the Ortiz stuff, but decided to give the cheaper GlowShift pod a try first. I'm happy enough with it for now.
#78
^^ I would opt for any other mounting locations if I cared about interior trim stuff, so the clock style holders would be my direction. I only have the single pillar pod, just for boost guage. I'm considering a panel where my stereo is just because I really don't listen to the radio in my civic, and another member here has a badass setup in that area of the dash that looks easy enough for even me to follow.
#79
***Not my picture*** this is JunVillaruz's hatch.. Awesome guage/switch panel setup.
Only thing I'd have to see about relocating would be my climate control unit. All I use is the heater and the slider switch hasn't worked in a couple years. I have to manually set the valve under the hood so, eh, and i have no A/C components to speak of.. I short, the cabin fan is all I have to worry about turning on. Maybe I can just wire that to the new switch panel..
Anyhow, that's a cool idea to follow!
#80
One of the best decisions I made was selling all my AEM gauges and buying an Aim MXL digital dash that does everything all in one. I know it was a little pricey but adding up the cost of pillars and a bunch of gauges was basically just as expensive.
#82
Just looked that up.. It's got a price tag to it but, Mother of God is it sexy!!
#84
That glowshift 3 gauge mounts on top of your oe pillar? Seems kinda janky i guess. I was thinking it was a replacement pillar. Ya those digital dashs are sweet but ya that price tag is heafty. Idk if im sold on digital stuff tho, i like the analog style stuff for the most part. Boost gauge is 50 and aem uego is 150 ig thats all i run so maybe leaning toward that ortiz one, for now at least. Can always upgrade later but moneys running low with all my other hobbies lol.
Also ran into an issue w tge throttle body. Got a 70mm skunk2 pro and went to put in the tps and it doesnt fit, its too deep. If my measurements are correct, to the screw on the skunk2 is .200 in, and my tps is .280 deep. I emailed tech support so guess well see. Only thing i can imagine is it being a jdm motor instead of usdm but would imagine theyd all be t he same to keep costs low.
#85
Yeah it was supposed to mount over the original trim and just screw into it. It was too bulky when out over the original trim, which why I cut the trim piece and ran a screw through the GlowShift pod directly into the metal of the pillar. Not the cleanest solution but it works for me.
#86
those must have been some HELLA expensive gauges you had!
#87
4 AEM digital gauges are going to set you back about $600 bucks, I also had the pillar pod and gauge cluster pod.
I got the Aim XML for 900 dollars but yeah if I buy a bunch of Auto Zone specials I’m sure it would be pretty cheap.
#88
Even Autometer "Stepper" motor gauges will cost around $250 each... and that brand is a "middle-of-the-road" product. Top brands like Defi, GReddy, HKS etc. are even more costly. Way back when, quality gauges were the only choice for monitoring engine vitals. Now, companies like AiM, RacePak, and AEM offer quality alternatives at comparable prices... thank God.
#89
got my tubrosmart boost gauge, turbosmart manual boost controller, and radiator mount kit. About the only things i have left is the skunk 2 megapower rr exhaust, aem uego, and gauge pod.
Emailed skunk2 anout this tps sensor and still no word back so guess ill have to call or something. Every video i look up everyone says it just drops right in but
it cleary sits to far out. So not sure what to do besides call and see unless anyone else has ran into this issue.
Have mY work car show this Thursday then i think im about out of excuses to not start putting this in lol.
#90
I wish you the best of luck trying to get ANY resolve from Skunk2 customer service. I use and love their products but despise their customer service...
#94
It's wU to the sOLdiEr!
calling them is always my first thing to do. i called them in the past for a few things and my experience was fine.
#95
#96
Moderator
It's probably changed since Brian Nichols left for Goddard. Not too surprising. Although I haven't had to contact customer service there in a few years.. who knows what skinny-jeaned, bearded morons took over the phones now.
#98
#99
Calling is an option obviously but im flat rate so any time im not turning a wrench im not getting paid. And I've been so busy with my other hobbies and aide work i havent even touched it in the past 2 weeks anyway.
