boosted and tuned with max rev and hondata check it out!!!!!!!!!!!!!!!!!!!!
This is how it goes, mild steet tune at 8.5 psi max rev kit with 440 rc injectors and hondata s200. 223.8 whp and 172.5 torque !!
list of motor parts on this car. 1995 4dr. gs-r b18c1 Eagle H beam rods SRP 9:1 pistions 81.5 bore size race engineering block guard ferrea 0.5 oversized intake and exaust valves bronze valve guides JDM type-r throttle body stock gs-r cams gs-r manifold port matched to throttle body maxrev turbo kit t3/to4e turbo rc 440 injectors hondata s200 with boost http://www.imagestation.com/picture/...3/fc6cbba4.jpg http://www.imagestation.com/picture/...0/fc9425ed.jpg Give me input please. what do you think about the power numbers at 8.5 psi???? THANKS FOR CHECKING OUT MY THREAD!!!!!!!!!!!! |
Re: boosted and tuned with max rev and hondata check it out!!!!!!!!!!!!!!!!!!!! (vtecpwred)
What are the specs on turbo and what kind of dyno was that?
Re: boosted and tuned with max rev and hondata check it out!!!!!!!!!!!!!!!!!!!! (Arturbo)
come on guys 31 views no postz...
I have a friend with an almost identical setup, just JE pistons, more boost, and bigger injectors and at 10psi he made 329whp, and at 19psi he made 415whp.
Numbers seem a bit low for your boost level. What trim size on the turbo, exhaust size, intercooler size? Those are going to make a difference as far as power levels are concerned.
Re: boosted and tuned with max rev and hondata check it out!!!!!!!!!!!!!!!!!!!! (boosted hybrid)
Ouch those numbers are scaring me. Im looking at the same compression pistons, same motor, and golden eagle sleeves, same injectors and hondata.
I sure hope my numbers are higher. |
Re: boosted and tuned with max rev and hondata check it out!!!!!!!!!!!!!!!!!!!! (intekragsr)
are you sure your at 8.5? that motor with what you've got could make close to that without boost.
Re: boosted and tuned with max rev and hondata check it out!!!!!!!!!!!!!!!!!!!! (AudioXtremes)
it does seem a bit low, you sohuld be making around 240
i would think u'd make closer to 260whp...thats what i have seen on similar setups
Re: boosted and tuned with max rev and hondata check it out!!!!!!!!!!!!!!!!!!!! (c1hatch)
very low numbers http://images.honda-tech.com/set1//smile/emcrook.gif but depend
is that a mustang dyno? to rich? timing? exaust? turbo trim? compression test? |
Re: boosted and tuned with max rev and hondata check it out!!!!!!!!!!!!!!!!!!!! (chidoks)
COMPRESSOR SPECS:
.60 A/R HOUSING 57 TRIM WHEEL TURBINE SPECS: .48 A/R HOUSING STAGE 3 WHEEL is this why my numbers are low ????????????????????? small turbo??? THANKS FOR ALL THE INPUT!!!!!!!!!!!!!!!!!!!!!!!! |
Re: boosted and tuned with max rev and hondata check it out!!!!!!!!!!!!!!!!!!!! (REVTurbo)
btw your air filter is sucking very hot air !
I was making 280 at 11psi on the same setup. 350+ HP at 14psi.
you have issues. |
btw your air filter is sucking very hot air ! mike |
Re: boosted and tuned with max rev and hondata check it out!!!!!!!!!!!!!!!!!!!! (MikeMAN)
is VTEC working? looks like it takes a dip and just stays flat and not peaking.
Re: boosted and tuned with max rev and hondata check it out!!!!!!!!!!!!!!!!!!!! (BoM)
The .48 is gonna hurt you some. Not sure how bad at that low boost though.
up the boost already and start tuning at the boost levels that really matter
Re: boosted and tuned with max rev and hondata check it out!!!!!!!!!!!!!!!!!!!! (bretx0r)
Re: boosted and tuned with max rev and hondata check it out!!!!!!!!!!!!!!!!!!!! (a z n t a k)
don't be rediculous telling him this guys.
those curves are terrible and indicate a problem either mechanically or with his tuning. upping the psi can be detrimental. you need to focus on getting the basic tuning right before you go increasing boost. next thing he blows his motor and comes crying here because all of you told him to up his boost! send me your ROM file and let me have a look if you would like. |
Yea, that tuning looks like it could be better.
Plus I bet the .48 a/r turbine is holding you back some. |
Re: boosted and tuned with max rev and hondata check it out!!!!!!!!!!!!!!!!!!!! (HXMan)
Get someone else to tune that thing.
Re: boosted and tuned with max rev and hondata check it out!!!!!!!!!!!!!!!!!!!! (MachAF)
Yeah those are really low. I made 240whp with a jackson s/c on 8 psi!!! On a b16a2.....
Granted that was stock compression, but when I put my turbo on and boosted 8 psi...it made like 280 whp... Something is not right. Like alot of people say....its all in the tune...fuel, ignition, etc... |
Re: boosted and tuned with max rev and hondata check it out!!!!!!!!!!!!!!!!!!!! (Boosted2ksi)
you might want to add a dumptube too, or you'll blow your a/c line http://images.honda-tech.com/set1//smile/emcrook.gif
my car made 310 whp at 9 psi and on a t3/t4
Thanks for all the input the tune was only 2 hrs on the dynojet and it can be better any input is always good.
