Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   boosted high compression (https://honda-tech.com/forums/forced-induction-16/boosted-high-compression-3116272/)
stowne78 Jan 10, 2013 06:36 AM
Re: boosted high compression
Originally Posted by Ash J. Williams (Post 48316645)
you COULD run O2 sensors with avgas, but it is not cheap, and you would have to clean the sensors often. it also isn't good for you, at all.
I made the mistake of buying a Bosch wideband sensor. The MTX-L computer/gauge is great, the sensor is pathetic. Anyway is brakleen fine to use for those sensors to clean them up? Maybe if I clean it every once in awhile it will last longer.
wantboost Jan 10, 2013 06:39 AM
Avgas is the best stuff on the planet, next to sex, Italian sports cars, and marrying Sasha Grey.
Of course you can't just drive onto the tarmac and fill your car up at every airport you come across. I think 100LL by my dads house is like 4.85 a gallon I think? We know the airport owner (he lets us do speed pulls down the tarmac for tuning) if you can bring a 55 gallon drum or some sort of container and fill it up.... if you know someone that works at a small airfield
evilpenguinking Jan 10, 2013 09:30 AM
Originally Posted by th3pwn3r (Post 48316942)
You're talking like you're Donald Trump but are running stock sleeves for some reason. Can you give us the reason as to why?
just testing the boundaries...no one got anywhere not taking chances. I know its stupid with stock sleeves, just wanting to try it out...
evilpenguinking Jan 10, 2013 09:58 AM
yea im running the ngk powerdex with ngk sensor
dcmatt Jan 10, 2013 10:09 AM
if your worried about inconsistency with pump E85 then try C85. if your really ballin then go with FTW purple. A good build for you to check out would be muckman's high compression build.
Muckman Jan 10, 2013 11:37 AM
Yeah!
wantboost Jan 10, 2013 11:40 AM
With high compression, stock sleeves, and boost... one good detonation event will shatter a sleeve
AFAccord Jan 10, 2013 03:36 PM
You wanted to shoot some videos of high boost pulls in the Accord? http://www.6thgenaccord.com/forums/i...ilies/deal.gif
yungmulacrx Jan 11, 2013 07:06 AM
Was this motor built to be all motor high compression in the first place? If so i think i would worry a little more about your p2w clearances.. Good luck
