Boosted GSR Head gasket
It seems My head may be warped on my engine. I've got a friend who has a spare GSR head he'll sell me. Works for me. But he suggested that I get an after market head gasket that was thicker than stock to drop the compression a bit.
Whats a good brand or what should I look for. Running about 7psi on a stock GSR (untuned)
Re: Boosted GSR Head gasket (IIISport.com)
cometic is the only brand I'll use these days.
they make a lower compression gasket for ya'.. however, as mentioned above, you shouldnt really need one at 7psi.. but if you plan to run a bit more boost, its a good idea to run one to give yuou some extra margin of error for your tune...
Re: Boosted GSR Head gasket (ykracing)
Y not just pull the head, take to machine shop and pay them $50 to check if its flat and if not, make it flat?
Re: Boosted GSR Head gasket (mike1114)
I'm going to have the head checked before I spend the money on the new head. But I was told if I have it shaved to make it flat again, that it will up the compression and that isn't what I want for a Turbo engine. Plus I really don't have the money for a valve/head job. I will probably get the new head cheaper from my friend. But I'm unsure of the price of a valve job. Right now I'm just hoping Its a blown gasket. My Radiator cap took a crap and blew all of the coolant out of my engine. it was seeping so slow I didn't notice it untill I was far away from civilization with no phone service. I drove it untill the Check Engine light came on then shut it off.
