BOOSTED B18C5 COMPLETE BUILD DAILY DRIVER 400HP?
#78
Re: BOOSTED B18C5 COMPLETE BUILD DAILY DRIVER 400HP?
Might end up putting this build off for a little while longer. I really want to save up and get a bigger turbo, bigger injectors, and water/meth kit before I get this car running again and get to the dyno but we will see what happens
#88
I think its crazy your not doing anything to strengthen the sleeves. You have a ton of money in parts and at 350-400hp your one instance of detonation away from cracking a sleeve. Never mind when you decide to turn up the boost. If sleeving isn't an option I'd at least recommend CylinderSupportSystem. They are proven and cheap. Other than that the car is badass.
#90
Moderator
#91
Exactly. When I eventually get sleeves I will more then likely go through GE
#95
Moderator
Depends upon the make of the inter cooler, and not just the size. A quality bar and plate from Garrett or even vibrant will exchange air at a better rate than a cheaper tube/fin. The mishimotos and precisions don't do well without large surface area exposure. So " getting away with" anything too small for your goal will just hurt you. All of the inter coolers that you see that display a "power rating" is for the power to the crank..not the wheels
#99
Good luck with the build.
#100
