boost is falling @ 36psi...s400 FMW 1.25AR
s400 FMW 1.25AR 993WHP
what could be the reason why boost won't go up at top end?
cam timing? manifold design? intake manifold?
using FR outlaw manifold, s400 fmw 1.25AR,
new dyno results after playing with cam settings...tuning MBT...04/20/14
Re: boost is falling @ 36psi...s400 FMW 1.25AR
bseries
s2pro1s
85mm 10ish CR x 89
JG manifold
60mm wg @ 1.5bar base pressure
while tuning this today, when I boosted the care up to 32psi, power was there already.
add more DC to the solenoid, 36psi then back at 32 at top end. add more DC @ 7trpm and up, and still 32psi....
s2pro1s
85mm 10ish CR x 89
JG manifold
Have you checked for a piping leak? Check all tubing to the boost control system.
May need a second solenoid to up the boost.
Are you monitoring backpressure?
no i am not yet monitoring back pressure. i am thinking of doing that next...
i wanted to stay away from the dual solenoid setup though. i think even if i put a solenoid on the side port of the wg, it will still drop @ top end.
dcmatt,
yes. if you see the graph @ 22psi, the pressure was holding quite good. a little creeping in fact.
dcmatt,
Looks like the turbo (although 94 lbs/min) is at its max flow at the current VE of your engine.
836 WHP is pretty close even with very good VE I guess + your dyno may be conservative..
Nah. Torque is still climbing when hp starts to break off. There is still more in it.
Thats true. Interesting enough though: engine seems to be saying: give me more and still makes more power, but boost starts dropping.
I still think this might be a case of 'turbo says no'
There is also a S400 71mm FMW for 'those kind of people'...
Anyways, awesome power man! Over 400hp per ltr is pretty crazy still.
Moderator in Chief
I don't think it's crazy this turbo is starting to peak. Youll need to ramp duty cycle with rpm to combat boost taper.
Could be. Guess I looked at it too quickly and thought it was torque.
I would expect about 900 around 37-38psi for that turbo. Seems like either the dyno doesn't have enough load or he has a leak/choke point in his setup.
Charge pipe is 3" all the way through. including using T1 a2w.
fuel and timing is approx 11.2-11.4 @ 22-24degrees.
anyway we think its turbo....ive set the solenoid to 100% at top end when the mid range is only 55% and makes 36psi....still at that numbers, its still dropping to 32 at high rpm.
Who is Mr Robot?
A quick way to see if its the turbo or solenoid is simply unhook everything from the wastegate, don't feed it a pressure reference and then do a dyno pull very slowly, see what pressure the turbo makes (obviously stop if boost goes too high or the AFRs go nuts)
Then that will tell you if you need another solenoid or if the turbo is out of breath
Who is Mr Robot?
That or make a block off plate and remove the wastegate all together.
At the power levels the OP is making, every little thing matters... from valve event timing, intake manifold design, runner length, etc. So there are a lot of variables that can affect performance
Maybe the motor has simply given its all at this point
Who is Mr Robot?
That's very true, that way you can data log under varying conditions.
Oh tepid, I love the way you did your back pressure monitoring setup on your car, if you don't mind I'm going to use it for inspiration on my civic and s13 builds
finally ran the car, boost still is falling at top end.
i guess its time to get a 72/74mm with a huge housing
