boost controller install, quick question.
Hi. Using a Tial 44mm WG, with a AVCR.
The 2 vac ports on the tial, the one on the side gets connected to vac, and the one on the top goes to the [com] port on the solenoid, and the [no] on the solenoid goes to vac source. Sound right? |
Re: boost controller install, quick question. (HamiltonRex)
oh yes.. for the vac source for the solenoid and wastegate, i am using the compressor housing.
Thanks. |
link to manual http://www.apexi-usa.com/pdfInstallation/45.pdf see page 47 of the pdf for external wg install
1. side port of wg to compressor hosuing 2. top port of wg to COM 3. tee into line #1 and run to NC so basically the side port of wg and NC port of avc-r need to go to the comp housing. NO port is NOT used in our appliction. i believe its more for factory turbo vehicles. |
Re: boost controller install, quick question. (dpetro1)
ok.. so on the solenoid valve i have to use NC
| All times are GMT -8. The time now is 04:58 PM. |
