boost controller?
can you use a boost controller on a stock dsm t25. it set at 8psi trying to lower it to 5 or 6 psi
Re: boost controller? (CRAZYHONDA)
I dont think the boost controller will lower the boost because once you reach the wastegate spring pressure that is what will finally dictate the low setting.Correct me if I am wrong H-T
Re: boost controller? (siblues)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siblues »</TD></TR><TR><TD CLASS="quote">I dont think the boost controller will lower the boost because once you reach the wastegate spring pressure that is what will finally dictate the low setting.Correct me if I am wrong H-T</TD></TR></TABLE>
Yes you are correct. |
| All times are GMT -8. The time now is 07:38 AM. |
