Bolting Turbo Directly to Exhaust Manifold?
BCICAN
I trust you Ricky, I just want to see how many others are doing it this way
Questions:
1.) How many of you are bolting your turbo directly to the exhaust manifold.... <U>WITHOUT</U> using that rectangular exhaust gasket in between the two?
2.) If you are, are you using any kind of gasket paste type of product?
3.) If so, what are you using? haha
Questions:
Re: Bolting Turbo Directly to Exhaust Manifold? (AF-P Dunc)
now i use the standard t3 metal gasket .
on my old dsm turbo setup, i used copper rtv and it never leaked.
milled and polished with nuthing else except a final coating of hondabond. hasn't leaked since put together. 4500 miles ago.
Re: Bolting Turbo Directly to Exhaust Manifold? (LVB18Civic)
Run the turbo flange and the manifold flange on the side of the chopsaw for that ghetto mill action, then cut a gasket out of an old pepsi can. Booya!!!
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LVB18Civic »</TD></TR><TR><TD CLASS="quote">I am not using a gasket on my setup and no leaks here. </TD></TR></TABLE>
Did you mill your turbo's flange? Or just bolt away and call it a day?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y7turbo »</TD></TR><TR><TD CLASS="quote">now i use the standard t3 metal gasket .
on my old dsm turbo setup, i used copper rtv and it never leaked. </TD></TR></TABLE>
I can't remember, but isn't that copper rtv not rated at taking the high temps when acutally touching the turbo?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 »</TD></TR><TR><TD CLASS="quote"> Run the turbo flange and the manifold flange on the side of the chopsaw for that ghetto mill action, then cut a gasket out of an old pepsi can. Booya!!! </TD></TR></TABLE>
haha that could work; however, I try to keep the ghetto-ness away from my car. I like spending the little bit extra and doin' 'er right
Thanks for the quick reponses guys! I'd still love to hear more opinions (obviously)
Re: Bolting Turbo Directly to Exhaust Manifold? (bjfisher)
I tried using a metal gasket and it leaked. Removed it and added copper spray and still leaked. Removed it again and found out the copper spray had disintegrated. Reinistalled with no gasket and it doesn't leak one bit.
Re: Bolting Turbo Directly to Exhaust Manifold? (EK k kay)
i was running copper RTV on my 16g but last time i took the turo off i didnt feel like putting any back on so i just slapped it back together and it hasnt leaked.
Re: (importdude2000)
i am running a gasket and have reused it once with no leaks. my turbo was brand new when installed, but i am using a used revhard mani, didnt mill it or anything. it seems with some of the good quality manis and turbos of today gaskets may not be necessary. ive never used one on my dp and it doesnt leak either.
Re: (dturbocivic)
Mani's like lovefab, full race, hytech, BMC, BLOX etc DO NOT need a gasket, any manifold as long as the surfaces are truly flat.
OEM turbo cars usually use cast parts which have a lot of imperfections (not completly flat) so they use a gasket that can crush and make up for the imperfect surfaces.
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bjfisher »</TD></TR><TR><TD CLASS="quote">"doin er right" as you call it, would mean using a gasket</TD></TR></TABLE>
True, but I would think having both milled flush would be a little more pimpin' haha.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 »</TD></TR><TR><TD CLASS="quote">Mani's like lovefab, full race, hytech, BMC, BLOX etc DO NOT need a gasket, any manifold as long as the surfaces are truly flat.
OEM turbo cars usually use cast parts which have a lot of imperfections (not completly flat) so they use a gasket that can crush and make up for the imperfect surfaces.</TD></TR></TABLE>
I fall in that category.....lovefab.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">no gasket/no sealant on my DD.</TD></TR></TABLE>
hmmm I have a gasket on there right now, but I might try the no gasket/no sealant approach. Thanks again for all the input guys
lilintegra25
01-18-2007 01:46 PM
