Blown Headgasket???? I need second opinion
Fixed!! Head gasket is not blown AEM EMS is locked on -17* on any RPM's of timing for some reason I went to AEM board to get some help Thanks HT
Updated Pics of the head gasket on the bottom TIA
I need help to figure out what is wrong on my car!! First:: it misfires really bad! second:: it wont accelerate anymore like before, the RPM wont get up faster anymore while i test drive it after i changed to the brand new spark plug, and the last is:: its smokes a lot while im driving, whit smoke!!!
i took pics of my exhaust and #3 spark plug and it's white.
TIA
Modified by rollydc69 at 11:36 PM 6/4/2006
Modified by rollydc69 at 6:50 AM 6/21/2006
TIA
Re: (coneheadsracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing »</TD></TR><TR><TD CLASS="quote">Whats your setup, especialy fuel management setup? Could be ringlands.</TD></TR></TABLE>
im using AEM 1040, Bosch fuel pump, RC 1000cc, Aeromotive Pressure regulator
Re: (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">leak down test</TD></TR></TABLE>
i dont have compressed air tank on my garage, i will try compression test later on.
Ringlands or headgasket?? what you guys think??
TIA
TIA
Re: (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">any oil lost?</TD></TR></TABLE>
no oil lost, i just did the compression test, with these results
#1 = 190
#2 = 190
#3 = 191
#4 = 195
CP 9:1 pistons.
TIA
#1 = 190
#2 = 190
#3 = 191
#4 = 195
CP 9:1 pistons.
TIA
it could be the headgasket.
when you feel a loss of power, it's because the head lifts under boost and you lose compression because of it..
same thing happened to me, minus the white smoke
Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">it could be the headgasket.
same thing happened to me, minus the white smoke</TD></TR></TABLE>
eventhough the compression is 190 across the board while we test it?? i hope is the head gasket, its easy fix
Re: (rollydc69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rollydc69 »</TD></TR><TR><TD CLASS="quote">eventhough the compression is 190 across the board while we test it?? i hope is the head gasket, its easy fix</TD></TR></TABLE>
static compression would be good, but when you are boosting, you're head is lifting lose compression during that time.
Re: (igo4bmx)
Update: took the head out today! i think its blown
The block, it has black stuff beetween cylinder #1 and #2 and between #2 and #4
The Head gasket
I have some blue/green stuff on my IM and Intake head, Race gas???? Id been running C16 all the time.
TIA
The Head gasket
TIA
Re: (rollydc69)
looks like the gasket is shot , looks like you had some head lifting issues , if you look at the bore opening on the gasket it looks out of round as if the head or sleeves have walked around on it , and the green stuff on the intake is from race gas
Re: (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA »</TD></TR><TR><TD CLASS="quote">looks like the gasket is shot , looks like you had some head lifting issues , if you look at the bore opening on the gasket it looks out of round as if the head or sleeves have walked around on it , and the green stuff on the intake is from race gas </TD></TR></TABLE>
how to avoid the head lifting , Increase the head torque?? i already torque it to 80 lbs/ft using the clevite assembly lube on ARP headstud.
Re: (rollydc69)
Your pix are too dark for me to tell much of anything. I think I would surface the head, put an oem intake gasket on, have the deck of the block checked for flatness and put on a new gasket. Torque your head to about 75lbs max as more than that can warp the head.
Re: (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA »</TD></TR><TR><TD CLASS="quote">one more thing how many times have you reused them studs ??? I only use them twice and thats it , they do stretch </TD></TR></TABLE>
really?? this is the second time im gonna used it, its less than 75 miles on the motor/set up
Re: (D-meet07)
Donkeeyyy
07-03-2010 05:39 PM
