Blow off valves, turbos, GTI - Rookie questions.
Old Member
A guy last night got at GTI and you can hear the blow off valve in his turbo.
Questions.
- What is blow off valve, what does it do?
- Do all turbos have them? How about supercharger?
- What about Turbo Diesels?
Questions.
Re: Blow off valves, turbos, GTI - Rookie questions. (GoLowDrew)
it bleed out air as yout throttle plate closes to prevent the air from returning to the compressor blade and spins the opposite direction (compressor surge)
Yes, all turbo has them, you may be able to get away from need to have one on an auto, since there's are no load when the throttle plate closes. It's a good insurance for your turbo
see above, all turbocharger system need to have one again as insurance for your turbo
stan
stan
Re: Blow off valves, turbos, GTI - Rookie questions. (Flamenco-T)
Not all turbo diesels have throttle bodies though. In that case a BOV is not a good idea. (I'm talking larger engines here such as Powerstrokes, ISB, etc)
Eventhough I am not that familar with the VW turbo diesels, I imagine those have throttle bodies. A BOV could serve a function here.
7mile
05-22-2017 10:03 AM
BigPlansNoMoney
01-20-2005 08:00 AM
Full-Race Geoff
11-11-2002 08:31 PM
