Is this block sleeved?
Hopefully I can pick this block up tomorrow, but I cannot tell if its sleeved or not. He said the block is not stamped. These are the pictures I was sent. In the second picture, it looks like there is another sleeve in that cylinder.. What is that? This is why I am confused.
http://img202.imageshack.us/img202/5135/czcr.jpg http://img5.imageshack.us/img5/8624/sspf.jpg http://img32.imageshack.us/img32/1841/mx9x.jpg http://img819.imageshack.us/img819/2052/8iy6.jpg |
Re: Is this block sleeved?
GE sleeves, the only companies that stamp/machine their blocks are benson and ERL
the discoloration is from the headgasket and just the age of the block, but yes, it is most definitely sleeved
Sure looks-like GE cooling veins. What's it bored-out to?
The sleeves may have been replaced (I'm trying to compare them to my flanged sleeve block). Better pictures would help. It's definitely not a "full-on" sleeved block (like GE or Darton MIDS).
At the best it's had the sleeves replaced and a block guard installed. I'd be weary of it though. Trust your instinct - if something doesn't feel/seem right then it most likely isn't. |
can someone explain why the second picture looks like it has a whole other sleeve inside it? what is it?
Originally Posted by peaceable
(Post 49228724)
Thats just the piston in part of one circle
like i told you, the headgasket will leave that line there over time.. take a green scotch-brite pad and gently go over the sleeve tops, it will go away. The upper sleeve support is classic GE sleeves, no blockguard is designed like that nor goes that low in the coolant passage, plus where each sleeve meets at the upper sleeve supports you can see the parting line between each sleeve, a dead giveaway trust me, it has GE sleeves and if the bores are round the length of the sleeve, shows no sign of dropping a sleeve (or rather a sinking sleeve), has no leaks at the bottom of the sleeves where they meet the block then you're good, assuming the price point is correct |
$1000 for a complete long block... cp pistons, eagle rods, gsr head, spun a bearing so itll need a new crank and rebuild. 120 miles one way drive as well.
so i may be an idiot but from the top those dont look like cp pistons
they could be, IIRC their b series turbo (9:1) piston has large quench pads behind the valve reliefs
best way to find out for sure (and your comfort) is email pics to GE (although I'll bet you your car, motor, and turbo setup that they are GE lol) and ask the guy for pics of the cp box, the label on the box with the part number and then a pic of the piston spec sheet... or email piston pics to CP |
It looks like the deck surface has been milled a lot. Would recommend that you measure piston to deck/head clearance before assembly.
*You may want to have it decked again to clean up the surface and you can have the machine shop measure p2d. |
ge sleeves cp pistons and what your circling is the top of the sleeve the piston is not tdc. with that said, if it spun a bearing at that low miles better check that block with fine tooth comb and check the line bore to
You'll need to line bore the mains, figure out why it spun a bearing, rods will need to be checked so will piston rings and pistons. There is a good chance you've got some bad parts there seeing its damaged (other than the crankshaft). Honestly in the end your not saving a dime. Sleeve your own block and build it.
or tell the guy you'll buy it as a bare block with main caps, that should drive the price down a lot and if the guy realizes the extent of the damage he might see that is his best option as well
