Best Valvesprings for Skunk2 PRO 1's
Hi
What are the best valvesprings to use on a Turbo LS/B16A application using Skunk2 Pro 1 cams : 9000 - 9500 rpm redline ??
Supertech
Skunk2 Pro series springs
Ive also received info on "special 100psi seat pressure" Supertech valvesprings - any feedback on these.
@ people using Pro 1's in Turbo applications ; which valvesprings are you using ??
Thnx in advance
Supertech
Thnx in advance
Re: Best Valvesprings for Skunk2 PRO 1's
skunk2 pro springs are made for pro cams and a 10k rev I just emailed them about that
last month other wise I wouldn't know either.
i think the 2 b series supertech springs at seat psi is 70psi and 85psi....i have the 85psi and was wondering if there still good for the pro 1's?
how stiff is the s2 pro springs?
Im using super tech springs with my pro 1's on my turbo car reving
to 10,300rpm and im having no problems with them. Made good at
low boost to 630@20psi
I have ferrea high pressure springs for my pro1's.(I think 100lbs seat pressure), I think I remember reading somewhere skunk2 pro series were 85lbs seat pressure. Obviously there are more important things than just seat pressure to worry about. I would have bought the skunk2's, but the ferrea's were a package deal, and if they grind away the cams, **** happens.
I guess the guy at skunk 2 lied to me then when i told him what i wanted and responded by telling me only about the pro springs and pro1's thats my bad and if you are going from their web site they test the springs at 11k and the pro1 and pro2 are still a "street/race" cam
If you are running our Pro Series cams, we will not recommend a Tuner Series spring. So technically nobody here lied. The Pro Series springs will tolerate revs up to 11k. The Tuner Series will support revs to 10k.
Hi guess need some advice..
I've a b16a high Comp just below 12:1
Ycp ctr style pistons
Skunk2 pro 1 cams
B18 intake
Toda gen 1 mani
K20 injectors
Walbro 255
I've stock rod bolts and head bolts.. Will this be OK? Rev limit be around 9k
Also need advice on the a dual spring
and what psi or lbs to use was thinking 70 to 80lbs but I've no idea.. Anyone with a similar build hit me up with part numbers and advice thanks guys
Skunk2 pro 1 cams
B18 intake
Toda gen 1 mani
K20 injectors
Walbro 255
Skunk2 pro 1 cams
B18 intake
Toda gen 1 mani
K20 injectors
Walbro 255
Skunk2 pro 1 cams
B18 intake
Toda gen 1 mani
K20 injectors
Walbro 255
What make 85lbs lbs spring? Thanks man
I'd probably go withgdifferent cams. Pro1s are gonna be a bit much for NA.
The Pro1s are pretty aggressive. I know they were once used NA like, 1000 years ago but lots of folks lost power rather than making it. They've shown to be quite the impressive bumpsticks for turbo though.
boosted k20
08-02-2005 07:36 AM
