best sohc vtec turbo head gasket?
Old 05-25-2004, 12:31 PM
spettinger's Avatar
Default best sohc vtec turbo head gasket?
just had a customer blow his stocker-- what are some upgraded head gasket options for the d series motors?
Old 05-25-2004, 12:33 PM
Gravy's Avatar
Default Re: best sohc vtec turbo head gasket? (91hatchattack)
cometic. no questions asked
Old 05-25-2004, 12:38 PM
fjt
fjt's Avatar
Default Re: best sohc vtec turbo head gasket? (Gravy)
COMETIC...... Even though they will blow too if not installed properly(or of youre not running ARP head studs)..I blew one and i was N/A and it was the Cometic for turbo/NOS applications.
Old 05-25-2004, 12:47 PM
USDM 4G VTEC's Avatar
IMO and experience the OEM ones are as good if installed properly
remember most people put too much oil on the studs or headbolts, and when inserting them, the oil rubs on the gasket and gets between the head and on the gasket
Old 05-25-2004, 12:50 PM
b16ahybrid's Avatar
Default Re: (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">IMO and experience the OEM ones are as good if installed properly
remember most people put too much oil on the studs or headbolts, and when inserting them, the oil rubs on the gasket and gets between the head and on the gasket</TD></TR></TABLE>
I'm going with that too, although if you were to go aftermarket cometic gets my vote. But stock will hold a lot. If your having problems blowing stock head gaskets you need to maybe look elsewhere for the problem.
Old 06-01-2004, 07:20 AM
X-Mazda 3 Racer's Avatar
Default Re: (b16ahybrid)
OEM is all we use.
titan101
09-23-2011 03:48 PM
prietito69
04-01-2008 06:27 PM
Jammersplace
09-12-2004 04:50 AM
under_psi
08-30-2002 09:28 PM
Quick Reply: best sohc vtec turbo head gasket?
