Best place for Wideband sensor?
Old 03-01-2006, 09:21 AM
f1 vtec's Avatar
Default Best place for Wideband sensor?
hi, just wanted to know where is the best place to tap for the wideband sensor. I have a ramhorn manifold and was thinking of tapping one of the horns, but i was thinking that it wouldnt give me the reading for all cylinders. Also im worried tapping the manifold may restrict exhaust flow(need all the flow i can get to spool the t67).
So where have you guys tapped yours. Advice and pics would be appreciated.
Also i require a simple wideband just for keeping an eye on the mixture will an AEM do the job.
Old 03-01-2006, 11:20 AM
Soccerking3000's Avatar
Default Re: Best place for Wideband sensor? (f1 vtec)
you want it about 10 inches down the downpipe, other wise the heat can foul the sensor.
Old 03-01-2006, 11:58 AM
tilt's Avatar
I've read the sensor will go whack if it's over 9xx degrees. The manifold will easily hit over 1200 so dont place it there. Like stated, 10-18" from the downpipe is ideal.
zaxfire69
05-19-2008 01:27 PM
1.8T_EG
12-05-2004 07:43 AM
B6tPoweredMx3
10-06-2004 05:41 AM
symba
10-06-2002 03:30 PM
Quick Reply: Best place for Wideband sensor?
